How to setup initail conditions in steady solution
Like Tree10Likes
Old   May 13, 2016, 06:40
Aja
aja1345 is on a distinguished road
Is solution converged?
Thanks
aja1345 is offline   Reply With Quote
Old   May 13, 2016, 06:53
Maxim
-Maxim- is on a distinguished road
You should change the range settings in your torque monitor so that you can see how much your torque value is still changing. In case your user points don't change a lot any more, it is worth checking out the results in Post.
As a next step, you read over the FAQ again:
Originally Posted by ghorrocks View Post
Maybe change the time steps a bit. What is your current setting?
If you would like to simulate a turbulent flow correctly, you can use that steady-state result as a initial condition for your transient simulation now.
aja1345 likes this.
-Maxim- is offline   Reply With Quote
Old   May 13, 2016, 07:15
Aja
Thanks.
How do i set this case? I am new in CFX?
Result is good. But I think that it can be better. Yes i will change time step.
presently i want to simulate steady state.
Old   May 13, 2016, 07:22
Aja
I studied the following case in FAQ:
Use Local Timescale Factor. A factor of about 5 is a good guess to start with. If this is successful you should run the final few iterations to convergence with a physical timescale (not local timescale all the way to convergence).
What is the exact meaning of bold sentences?
Can't I run with a local timescale factor to end?
Old   May 13, 2016, 07:23
Maxim
right click on your monitor - monitor properties - range settings - set manual scale (linear).
Since you are new, you should try to figure those little things out yourself. Click through all the settings over and over again - that way you will learn more quickly than us telling you every step on the way.
What is your current time step setting? Auto time scale = 1?
I wouldn't touch local and physical timescales as a beginner. For steady-state auto timescale is usually good enough.
aja1345 likes this.
Old   May 13, 2016, 07:28
Aja
Thanks.
I use physical timescale=0.0005.....
Old   May 13, 2016, 07:53
Aja
Should I decrease physical timescale or increase?
I think that I should decrease it.
Old   May 13, 2016, 08:03
If the convergence is jumpy then decrease it. If the convergence is steady but slow then increase it. If the convergence is steady and rapid then leave it.
Also if the convergence proceeds for a while then flat-lines then try increasing it (but read the FAQ on further details for what to do here).
aja1345 likes this.
Old   May 13, 2016, 08:05
Aja
I decrease physical timescale to 0.00005....But residuals are as follows:
Old   May 13, 2016, 08:27
Aja
Thanks.
on the suction and pressure side is almost 3 and it is ok.
But on the tip is almost 1. I think this value is not suitable. Right?
When i increases number of node on the tip, total number of mesh is much more than 1500,000 cells. and My Laptop is weak!!! number of 1400,000 cells is better for me. Have you any idea?
Old   May 13, 2016, 08:33
Your convergence looks like it is converging for a while then flat lining. So then you should try increasing the time step.
If that does not work the FAQ describes the other options available to you.
You need to do a mesh sensitivity study to determine whether your near wall resolution is acceptable. The acceptable resolution changes for different simulation types.
If your simulation is too large for your computer then get a bigger computer, or network computers together. CFD is very computer intensive and always has been.
aja1345 likes this.
Old   May 13, 2016, 11:15
Aja
With physical timescale=0.000275, Residuals are as follows:
I think that convergence is again related to mesh a bit. particularly tip gap mesh because on the tip is almost 1..what is your opinion?
Old   May 13, 2016, 11:28
Aja
Old   May 13, 2016, 11:56
Aja
Old   May 13, 2016, 14:21
Opaque will become famous soon enough
Whenever residuals remain constant, or oscillate around a level (mean value remains constant), it is a good practice to visualize the region where this value is located.
Post-process the region of interest to determine if the problem is a mesh quality issue, or a unresolved physics. Anything else will consume a lot of time of guessing what is next.
Hope the above helps,
Opaque is offline   Reply With Quote
Unsteady simulation with steady solution as initial value kiddmax OpenFOAM Running, Solving & CFD 8 August 20, 2015 06:12
is it possible to predict how long it takes to reach steady state solution in unstead Alimohamadi_nasr CFX 4 November 11, 2013 07:11
Transient Solution looks like Steady State ljwnow FLUENT 0 March 26, 2012 02:54
Steady solution from Transient simulations wawa FLUENT 2 November 9, 2010 18:44
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
