how to use CFX coupling with external Fortran procedure |
March 15, 2016, 22:31 |
Ian
Rep Power: 13 |
hi everyone,i want to use CFX compute waterhammer,i have use Fortran compile method of characteristics,i want to simulate 1D-3D,but MPCCI did't have port to connect CFX and Fortran, can use CEl or CCL to compile method of characteristics and compute in CFX?
thank you ! |
March 16, 2016, 02:53 |
Rep Power: 144 |
I would recommend you use a user defined CEL function to do your boundary condition between the 1D and 3D sections, and you put your MOC code in the fortran for the CEL function.
March 16, 2016, 03:50 |
Ian
Rep Power: 13 |
if I want to update the boundary condition every time step according to the results calculated by Fortran, then CFX passes the simulated values to Fortran in next step, how can I make this kind of two way coupling with CEL function?
March 16, 2016, 03:52 |
Rep Power: 144 |
Put your fortran in the routine which defines the boundary condition for CFX. To do this you need to define a user variable with fortran in CFX. Then you do not need to pass values - the fortran will run as a part of CFX.
CFX 15 & Intel Fortran | papteo | CFX | 4 | December 15, 2015 07:06 |
User Fortran with CFX 14.5.7 on winnt_amd64 | HLo | CFX | 22 | December 13, 2015 09:26 |
How to get vertex(node) number in CFX user Fortran.. | flyply | CFX | 4 | February 4, 2014 20:51 |
cfx a mechanical thermal coupling | keeper | CFX | 1 | May 28, 2013 22:34 |
How to set environmental variables of Intel Fortran +CFX? | Christine MO | CFX | 0 | September 23, 2011 12:11 |
