February 25, 2016, 11:02 |
Normal Velocity on an Inclined Plane
Rep Power: 12 |
Hello, does anyone know how to calculate/display the normal velocity on an inclined plane in CFX-Post ?
February 25, 2016, 14:17 |
Rep Power: 33 |
Create the plane,
Create a vector plot, select projection method: Normal Hope the above helps, |
February 25, 2016, 15:44 |
Rep Power: 12 |
February 25, 2016, 16:34 |
Rep Power: 33 |
Define a new variable
Normal Velocity = Normal X * Velocity u + Normal Y * Velocity v + Normal Z * Velocity w Create contour for Normal Velocity.. |
February 25, 2016, 18:02 |
Rep Power: 12 |
What exactly does represent ''Normal X'' for example ? It could be Y vector, Z vector, YZ plane ... Sorry, but I'm not sure I fully understand the formula.
A simple example, if I apply this formula on a XY plane, that will be the Velocity z ? |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 18:24 |
Velocity within symmetry plane..JOB DEPENDS ON ANSWER! | prikeyma | FLUENT | 3 | September 10, 2010 11:52 |
Normal velocity at the symmetry boundary | Seventy | FLUENT | 1 | October 26, 2009 07:52 |
