Turbulence Model for Confined Jets
Old   June 3, 2014, 20:48
Question Turbulence Model for Confined Jets
Lucas Figueiredo
lucasphp is on a distinguished road
Good afternoon,
I am studying the impact force produced by a jet colliding against a wall.
The distance between the eject nozzle and the wall is variable.
The study fluid is water and the Re on the nozzle is about 80000. The turbulence model chosen is the SST.
After some tests, I noticed that the SST model doesn't fit exactly with the experimental data. To explain better my question, there is a curve in the attachment (from a study about evaluation of modified two-equation turbulence models for jet flow predictions.) that compares different turbulence models on the centerline velocity of a jet.
The problem is the delay in velocity to decrease, which is generating impact force larger than the experimental data in that range.
So, the question is: Is the SST model the best turbulence model available on CFX or you, CFD experts, have a better solution for me?
Thank you,
Lucas
lucasphp is offline   Reply With Quote
Old   June 4, 2014, 07:26
Have you done the basic accuracy checks? http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
In particular have you checked the inlet and atmospheric turbulence intensity is correct?
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 17:25
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
