Thrust in Axial flow fan for different inlets |
April 19, 2014, 07:31 |
Tijery
Rep Power: 15 |
Hello Dear CFX users,
I am simulating axial flow fan for different inlet geometries viz.sharp inlet(zero camber radius) and smooth inlet (bell mouth) . The inflow conditions are non-symmetric i.e I have certain cross flow velocity. This means I have large flow separation region at the fan inlet for sharp inlet and no flow separation at the bell mouth inlet region. While calculating the thrust generated by fan I am getting higher values. And also surprisingly thrust values for sharp inlet is higher than the smooth inlet. I tried of monitoring the force_z@single blade , which is reaching to maximum value at the separation region. And also for the total thrust I used cfx expression as Thrust=force_z@rotorblades+force_z@statorblades +force_z@hub what is the right expression for the thrust generated by the axial flow fan in CFX. do I need to subtract any momentum force . please help with the right expression . Thanks you |
April 20, 2014, 07:42 |
Rep Power: 144 |
The force acting on a body has to be transmitted to the body through the surfaces. Assuming you have enough of the surfaces of the body that summing the forces over it is meaningful - then no, you do not have to include momentum differences in the fluid.
How have you modelled this? Can you show an image? |
April 20, 2014, 07:48 |
Tijery
Rep Power: 15 |
I used sliding mesh method to model the rotation. modelling is done by using multi domain method.
Whole model is divided into three domains likely Rotor --- Rotorblades, rotorhub and rotor duct Stator --- statorblades, statorhub and stator duct Domain -- Inletlip, and out domain I used GGI interface to connect the domain -rotor , rotor-stator which is rotating. and stator -domain is stationary. Axis of rotation is around z axis. I used the thrust expression Thrust=force_z@Rotorblades+force_z@rotorhub+force_ z@rotorduct +force_z@statorblades+force_z@statorhub+force_z@st atorduct is this right expression to find the Axial thrust. or if I calculate the force acting on exit plane of plane i.e. Thust=force_z@exit plane at stator outlet help me in solving this issue .. Thanks regards |
April 20, 2014, 08:37 |
Tijery
Rep Power: 15 |
I attached the model ..pic
April 21, 2014, 00:26 |
Rep Power: 144 |
If this is something like an engine in a nacelle on a wing (like an aircraft) then you really should include a domain around the engine to allow air to bypass the engine if it wants to. This is especially for cases where the incoming air is not aligned with the engine - this will change the amount of air passing through the engine.
April 21, 2014, 06:51 |
Tijery
Rep Power: 15 |
You mean my domain modelling is wrong or do I need to include the bodies around it to get the right value of Thrust ?
Actually I have the domain on top , which span 5 fan diameters in all three directions. |
April 22, 2014, 07:04 |
Rep Power: 144 |
No, it is the air flow which bypasses the engine I am referring to. So some air can bypass the engine, and some goes through the engine. And the amount which takes either path will depend on the flow conditions, engine operating point and many other things - including angle of incidence.
April 23, 2014, 20:29 |
Tijery
Rep Power: 15 |
what is the effect of the inlet duct shape on the generated thrust.
let if I have two types of inlets 1.First one with Zero camber radius 2.Second with specific camber radius. especially in the presence of crossflow .. |
April 24, 2014, 04:44 |
#9 |
Rep Power: 144 |
I have no idea. This is your area of research, not mine.
But sharp inlet corners cause separations and cross flow at the inlet will also cause separations and I know that a fan operating in a partially separated/partially attached flow is not going to be running very well. |
fan driven flow, Fan BC validation (getting lost) | soonic | OpenFOAM Running, Solving & CFD | 0 | July 7, 2013 20:16 |
Axial fan Efficiency Goals calculation? | Sanghyun - PARK | FloEFD, FloWorks & FloTHERM | 1 | February 18, 2013 12:20 |
Axial Fan | Russ | FLUENT | 8 | July 7, 2006 14:59 |
Fluent 2D Model - Axial Fan in a Duct | J | FLUENT | 0 | April 18, 2006 03:25 |
Model Axial Fan | Chien-Chi Chao | Siemens | 1 | February 1, 2001 23:13 |
