A flow field simulation of a centrifugal compressor |
September 18, 2013, 00:28 |
aysiyi
Rep Power: 14 |
problem description:a passage of impeller, a passage of diffuser and a volute. during the solving,the mass flow of inlet and outlet are steady,but they aren't equal. I don't know why? the interface of diffuser and volute is "stage", is it right?
September 18, 2013, 08:10 |
DB
Rep Power: 15 |
Are you checking both the inlet and outlet of rotating frame ?
-D.B |
September 18, 2013, 09:13 |
aysiyi
Rep Power: 14 |
Both the inlet and the outlet are static
September 18, 2013, 09:15 |
aysiyi
Rep Power: 14 |
September 18, 2013, 09:55 |
DB
Rep Power: 15 |
I mean where are they located ?, can you mark them in your figure ?
It might be possible, u r seeing a single passage value at inlet and a full passage value at exit
-D.B Last edited by D.B; September 18, 2013 at 09:55. Reason: typo :P |
September 18, 2013, 10:33 |
Benny
Rep Power: 14 |
"stage" is wrong. you need "frozen rotor"
September 18, 2013, 21:12 |
aysiyi
Rep Power: 14 |
At inlet is a single passage value, and at the outlet is a full passage value.
September 18, 2013, 21:26 |
aysiyi
Rep Power: 14 |
September 18, 2013, 21:29 |
#9 |
aysiyi
Rep Power: 14 |
The initialization of flow field for time accurate, unsteady simulation and BC | zhengjg | SU2 | 3 | September 29, 2017 16:38 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
Qualitative Observations of Mean Flow Field | Josh | CFX | 4 | July 9, 2010 17:52 |
centrifugal compressor | siva appanna | Main CFD Forum | 5 | February 13, 2006 22:07 |
How to model a flow inside centrifugal compressor? | starPlatinum | Main CFD Forum | 0 | October 26, 2003 10:03 |
