saeed
Rep Power: 13 ![]() |
Hi all
I am attempting to calculate distance between two vortxes behind a submarine by using ansys cfx. This distance is calculated by vorticity contour (contour of velocity curl in cfx post). Distance between stream lines is also calculated. Why this two distance is different and non equal? Cheers, Saeed |
Rep Power: 144 ![]() ![]() ![]() ![]() |
I do not understand what you are asking. Are you asking why is a vorticity contour a different distance apart compared to some streamlines?
saeed
I am need to obtain distance between two vortexes due to flow over a submarine.
I think that this distance can obtain from vorticity contour or 2D streamline in cfx post that this two value (value from vorticity contour and value from 2D stremline on plane perpendicular to submarine) must be equal. but result from vorticity contour is not equal to 2D streamline. why? |
An image would help.
But it seems pretty obvious that the vorticity approach and the streamline approach are defining the distance differently and therefore return different values. Why do you expect them to be the same? |
saeed
I think that location of vorticity is where that streamline rotate.
below image of streamlie CFX0.6.jpg below image of vorticity contour CFX10.7.jpg |
Your mesh looks very coarse. Have you tried a finer mesh?
Presenation of vortex strength and velocity concept? | fruitkiwi | Main CFD Forum | 0 | September 26, 2012 23:08 |
vortex cause pressure gradient or pressure gradient induce vortex? | fruitkiwi | Main CFD Forum | 4 | June 12, 2012 02:12 |
creating vortex core line | aay023 | Main CFD Forum | 0 | September 15, 2010 22:49 |
turbulent scales of forced vortex and free vortex | lcw | Main CFD Forum | 3 | September 1, 2005 14:40 |
Free vortex - forced vortex | Armin Hofstädter | Main CFD Forum | 2 | November 17, 1998 19:55 |
