November 5, 2012, 08:27 |
#21 |
Isa.Ebtehaj
Rep Power: 14 |
Unnamed.txt
my CCL is above file when i want use solver, solverrun and in iteration 200 solver exited because erroor code 1 is occured |
November 5, 2012, 09:01 |
#22 |
your ccl looks normal. ghorrocs (http://www.cfd-online.com/Forums/cfx...tml#post390275) answered your questions (for both error 1 and 255), why you don't try his solution and come back to let us know if it helped?
-- Kyriakos Vafiadis Mechanical Engineer, PhD candidate |
November 5, 2012, 09:58 |
#23 |
Chris DeGroot
Rep Power: 18 |
In your CCL:
FLUID DEFINITION: air Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: water Material = Air at 25 C Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END Check your definition of "water". It seems that what you have called water is actually air. Could be some inconsistency in your expressions because of this. |
cfx error, cfx14 |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 03:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 14:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 06:59 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 05:47 |
