November 18, 2024, 00:33 |
thermosyphon code simulation
Camila Solano
Rep Power: 2 |
I need help with a udf code for a thermosyphon simulation. 2d solid domain, treated as a black box using thermal resistance model. The goal is to update the evaporator, condenser and adiabatic length based on the heat transfer values, and then use the lengths values to calculate the thermal resistance equation in a iterative process.
if interested, contact me either here or my email is thebaddest.srmy9@gmail.com thank you. |
December 15, 2024, 23:58 |
Isolle Futa
Did you fix the problem? Please share your solution with me too.
ansys 23, cfd, udf code |
Transient simulation gives worse results than steady state simulation | jgross | CFX | 12 | January 21, 2021 13:21 |
How to run multiple cycle pulsetile flow simulation in Ansys fluent using UDF code? | Md Al Amin Sheikh | Fluent UDF and Scheme Programming | 4 | January 28, 2020 12:55 |
[Other] Comparing OpenFOAM to another code: advice on dealing with meshes? | SFr | OpenFOAM Meshing & Mesh Conversion | 1 | June 11, 2016 13:02 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 16:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 09:10 |
