Home > Forums > Software User Forums > Autodesk Simulation CFD
regarding cfdesign tool
Old   November 27, 2008, 02:10
Default regarding cfdesign tool
Ramamoorthy
I am using cfdesign tool. I am solving fan related problems and solution is not converging after hundreds of iterations even though mesh is good. tool is giving some new errors and warning. Pls clarify.
Old   December 30, 2008, 04:14
Default Re: regarding cfdesign tool
Benarji
How can you say that Mesh is good. Did you check the diagnostics of the mesh? More importantly did you define the problem correctly and applied the necessary boundary and ambient conditons. Pls check these. If you are facing same problem again, check the under relaxation factors. After doing all these things, if you are facing same problem read the 'Errors and Warning' carefull and try to rectify these. I hope this will solve your problem.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFDesign V10 and Solidworks 2010 sonodelirii Autodesk Simulation CFD 1 August 25, 2010 21:11
CFdesign problems gaussist Autodesk Simulation CFD 3 July 8, 2009 11:41
Can we make a CFdesign Forum Ram Main CFD Forum 1 February 2, 2009 10:50
Problem when launch Cfdesign from ProE Monford Autodesk Simulation CFD 2 September 22, 2008 21:40
