Does ANSYS design modeler support 3D MAX extension file? |
August 18, 2019, 05:08 |
Ontario
My geometry is made in 3D MAX software the file type is .max can anyone please tell me that can i import .max file into design modeler or space claim of ansys 19.1 version for simulation?
August 22, 2019, 05:40 |
#2 | |
Huynh Phong Thanh
Rep Power: 13 |
August 25, 2019, 13:26 |
Gwenael H.
Rep Power: 20 |
Hi Ontario,
As Huynh suggested a .stl file could be an option. Depending on how you created your geometry in 3DS max I would rather recommend you to export it into a CAD format rather than faceted data as a stl (as it's less precise and often you'll need to convert the stl data to surface / volume data before running a simulation). 3DS max offers a lot of different CAD export format that are compatible with ANSYS directly (sat, iges, IPT, sldprt, etc...). Have fun |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
