How to make periodic condition between two surface in two parallel pipes |
October 31, 2018, 04:27 |
Ahmed Awwad
Rep Power: 8 |
My case is modeling fluid flow and heat transfer through U-tube pipe, and I want to simplify it by making periodic condition between the outlet of right pipe and inlet of the second pipe as shown in the attached figure.
I used tetrahedral surface mesh element and sweep method. Should I define the periodic condition in meshing or in Fluent? and how to do it? |
October 31, 2018, 04:45 |
Andrea
Rep Power: 16 |
Hi Ahmed,
I think you are looking for the mesh/modify-zone/make-periodic command in the Fluent TUI. You will have to specify the IDs of the two boundaries that you want to make periodic and that you want to impose a translational (or rotational) periodicity. Once periodicity is imposed between the two boundaries you can use the Periodic Conditions tab to include additional features (such as an imposed pressure drop/mass flow rate). Andrea |
October 31, 2018, 05:18 |
#3 | |
Ahmed Awwad
Rep Power: 8 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
Parallel computation using periodic boundary conditions | AEMD | SU2 | 2 | March 27, 2014 00:41 |
[ICEM] Periodic condition on effusion cooling model | BahaZero | ANSYS Meshing & Geometry | 0 | July 15, 2013 16:51 |
[swak4Foam] some errors in compiling groovyBC in OF220 | immortality | OpenFOAM Community Contributions | 10 | April 1, 2013 04:46 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 12:51 |
