March 28, 2018, 20:12 |
joint beam to a solid problem
javier
Hi everyone!
im making a model (static structural) using steel material. this model has a cyclic load (displacements), im using a fixed joint to link a beam (solid element) to a beam element (beam 188 with cross section). the problem appears during the solving process when a message appears: x JOINT ELEMENTS WITH LAG MULT OPTION DO NOT SATISFY JOINT CONSTRAINT CONDITIONS on the other side of the beam element, i put a displacement support which is moving in one axis the system with tabular displacements. The geometry that im using was drawn in autoCAD and im using large deflections analysis. can you give me some tips or advices to solve my problem?. |
beam element, joint, large deflections |
Solid body 2-axis Rotation Problem | hongsuny2333 | CFX | 3 | December 30, 2015 05:37 |
[ICEM] Problem in solid mesh at ICEM CFD HEXA 3D Elbow Tutorial | sajjad7 | ANSYS Meshing & Geometry | 1 | October 16, 2015 06:46 |
convergency problem with Solid Pressure Model | commonyue | Main CFD Forum | 0 | March 30, 2010 06:18 |
comsol cantilever beam problem | bhu47 | COMSOL | 0 | June 30, 2008 15:59 |
FSI problem with topology of 3D beam via UDF | greg | FLUENT | 7 | July 17, 2006 06:32 |
