How to reduce Skewness
Like Tree1Likes
  • 1 Post By Cagatayemre
Old   February 15, 2018, 07:25
Default How to reduce Skewness
Formula Student
fsaeengineering is on a distinguished road
Hi, I got an intake manifold meshed with tethrahedrons and hexa type.
Skewness is about 0,87 but when I add inflation for boundaries maximum Skewness value goes up to 0,99
bad skewness points are in the attachment
Any suggestions?
fsaeengineering is offline   Reply With Quote
Old   July 25, 2018, 13:42
Çağatay Emre Ayhan
Cagatayemre is on a distinguished road
Try to increase the followings
nSolveIter
nFeatureSnapIter
nRelaxIter
Increase surface feature refinement and surface refinement.
Set maximum skewness to a lower value in meshQualityDict.
and
Dont use tetras on that zone. Non orthogonality is also a problem in terms of tetra cell shape.
brunazzo likes this.
Cagatayemre is offline   Reply With Quote
Old   July 25, 2018, 20:44
RedoFromStart is on a distinguished road
Are you sure that you added inflation to the whole interior boundary?
If inflation ends abruptly, it makes highly skewed elements.
In order to increase quality of cells near sharp edges you have to refine that area or make chamfer or fillet.
Although your quality looks pretty bad even without inflation so I would recommend you to refine mesh in problematic areas. (Areas with skewness >0.7)
RedoFromStart is offline   Reply With Quote
How to reduce skewness in GAMBIT? lyzheng87 ANSYS Meshing & Geometry 3 April 25, 2016 03:16
[ICEM] how to reduce maximum cell skewness Adila Anbreen ANSYS Meshing & Geometry 4 December 22, 2015 08:25
[ICEM] How can i reduce the skewness in this meshing??? gnut1989 ANSYS Meshing & Geometry 2 January 6, 2015 06:03
[ANSYS Meshing] how reduce the skewness factor? sara22 ANSYS Meshing & Geometry 0 May 13, 2013 15:28
Severe nonorthogonality and severe skewness problem qtian OpenFOAM Running, Solving & CFD 2 January 22, 2008 19:47
