Piston cylinder with fluid on both sides
Old   October 11, 2017, 21:34
Post Piston cylinder with fluid on both sides
Aida
rmawsu is on a distinguished road
I am going to model a hydraulic piston-cylinder while there are fluids on both sides of the piston (preferably two different fluids). The piston should move based on the pressure difference of the fluids on both sides. I have already tried using rigid body solution and immersed solid in CFX, but the fluid moves through the piston even with high momentum scaling factor and considering smooth inside ims= t expert parameter.
The other problem is that I am not able to set two different fluid zones on sides of the piston.
I think this modeling should be similar to what happens in free piston engines but I haven't found any work on those engines using Fluent or CFX.
Does anyone have any idea how I solve these issues?
Any help would be greatly appreciated.
rmawsu is offline   Reply With Quote
Old   October 12, 2017, 00:45
Christophe is on a distinguished road
There are two approaches to this. One is create a 3-d solid which overlaps the fluid domain and then simply acts as a source term to restrict the motion of the fluid based on the momentum scaling factor and the velocity differences, which you've tried. The other is to model the piston as a void in the fluid domain and assign those surfaces as rigid body. There's a CFX tutorial to try. Chapter 22 I believe which is a spring loaded pressure relief valve, to introduce the concept.
Christophe is offline   Reply With Quote
free piston engine, piston, piston cylinder, piston motion
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Moving Piston And cylinder saeidhomayounslm FLUENT 0 July 21, 2014 04:11
how to simulate a VIV of the cylinder in a fluid domian use rigid body solution? Mal CFX 13 April 14, 2014 14:44
simple 2d open ended cylinder with moving piston: dynamic meshing query lmarf88 ANSYS 0 January 6, 2014 10:55
Fluid in a rotating cylinder Fluid Novice Main CFD Forum 1 December 17, 1998 18:25
