ANSYS stack trace error when running 2-way FSI in command line
Old   June 6, 2017, 08:31
Default ANSYS stack trace error when running 2-way FSI in command line
raz
raz is on a distinguished road
I'm trying to execute the system coupling example from the ANSYS System Coupling User Guide (http://148.204.81.206/Ansys/150/Syst...rs%20Guide.pdf page 105 ) via the command line and when I run the three .bat files (coupling, fluid and structural), the structural outputs the following error:
*** WARNING *** CP = 0.827 TIME= 12:27:13
Tcl command ""C:\Program Files\ANSYS
Inc\v161\ANSYS\lib\scripts\AnsServer.tcl" 5generated a stack trace.
Check the ANSYS output for details.
tcl generated the following stack trace:
ANSYS SERVER MODE FAILED ON PORT 52459 with error couldn't open socket: address already in use
while executing
"Start"
while constructing object "::AnsServerPrimary" in ::AnsServerObj::constructor (body line 8)
invoked from within
"AnsServerObj AnsServerPrimary -port $port -startup manual"
invoked from within
"if {[info exists argc]} {
if { ${AnsServer::Init} } {
package provide AnsServer 1.0
} elseif {$argc >= 1} {
set port [lindex $argv 0..."
(file "C:\Program Files\ANSYS Inc\v161\ANSYS\lib\scripts\AnsServer.tcl" line 863)
I am not particularly good with programing so I was wondering if anyone has any idea what this means.
Thanks guys
raz is offline   Reply With Quote
ANSYS Fluent FSI tutorial kozden FLUENT 7 July 5, 2013 10:42
Post Process FSI data in ANSYS niraj12321 ANSYS 0 August 6, 2010 19:17
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
MFX - for FSI between Ansys Multiphysics and CFX? Zerocles CFX 1 June 5, 2006 09:23
