How to analyze compression process of engine?
Old   July 10, 2015, 02:37
Lightbulb How to analyze compression process of engine?
Pradeep
pradeep6890 is on a distinguished road
I have modeled a piston top and need to analyze the flow of fuel during the compression stage from bottom to top of the cylinder.
How to set up the problem and solve it for certain crank angles?? how to visualize the velocity profile and turbulence happening inside??
how to include moving mesh in fluent and generate result?
Whats the source code for moving a piston in cylinder
pradeep6890 is offline   Reply With Quote
Old   July 15, 2015, 09:19
Default dynamic mesh isnt moving
Pradeep
i modelleda piston and applied dynamic mesh and set preview motion for a particular crank angle but the mesh is not moving. kindly help me solve it.
fuel flow, piston motion
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
engine simulation with valve motion and spray process xianqiejiao OpenFOAM Programming & Development 3 April 30, 2015 10:14
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) kelvinlim Main CFD Forum 2 January 26, 2012 23:19
CFX model of diesel engine intake & compression Gareth Floweday CFX 5 May 2, 2002 04:54
compression stroke in piston engine Hassaneen Siemens 12 December 29, 2000 13:30
