FEA of hyperelastic arteries in ANSYS APDL
Old   December 15, 2014, 10:56
Default FEA of hyperelastic arteries in ANSYS APDL
Killian Chellar
ChellBells is on a distinguished road
Hi all,
I am attempting to model an artery under internal pressure in ANSYS APDL.. This is my current attempt..
select solid 8 node 183 element type (and specify thickness)
select 5 parameter Mooney-Rivlin (for which I have constants)
create quarter area model dimensions
map mesh with quad area elements
Apply symmetry Boundary Conditions to artery inner cut lines
Apply pressure load on internal area line
Activate large deformation (NLGEOM,ON)
Solve using static analysis
This approach works fine for linear-elastic materials, but I cannot understand why it yields no results in this situation????
ANY ADVICE?? Thanks in advance
ChellBells is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
[ICEM] import icem mesh into ANSYS APDL fariba ANSYS Meshing & Geometry 5 May 21, 2016 03:31
Honeycomb Panel FEA in ANSYS prateekg92 ANSYS 3 November 19, 2014 07:02
Ansys mechanical APDL problem. russogianluca90 ANSYS 0 October 13, 2014 08:38
Exporting fluent melting/solidification model results to ansys mechanical apdl omair11 ANSYS 3 August 28, 2013 07:22
