Boundary Layer Inflation across a 90 degree bend
Old   September 23, 2014, 14:23
Default Boundary Layer Inflation across a 90 degree bend
Ravinder Gill
gill11a is on a distinguished road
In my analysis, i need a boundary layer inflation across several 90 degree bends (corners) in my geometry. I am getting a good continuous mesh inside of a corner, but on the outside of a corner, the mesh is really bad ( as you can see in attached screenshots).
Any help will be much appreciated.
Thanks in advance.
gill11a is offline   Reply With Quote
Old   September 23, 2014, 21:56
hwet is on a distinguished road
which software is this? you can just get away by making a curve instead of a sharp 90 degree bend, it should not make a big difference to the simulation.
hwet is offline   Reply With Quote
Old   September 23, 2014, 21:59
it also appears that you have different boundary layer inputs for the vertical and horizontal parts, or atleast they have different diameters which is resulting in the different growth rate of the inflation and hence the bad mesh. also you cant judge a mesh by how pretty it looks rather look at the mesh quality from the software and decide if it is good or bad.
Old   September 24, 2014, 02:20
rahul kumar
R4RAHUL is on a distinguished road
I agree with the hwet you can draw a small curve at the bend
R4RAHUL is offline   Reply With Quote
Old   September 24, 2014, 12:56
Ravinder Gill
Hi everyone,
Drawing a curve instead of 90 degree bend will not represent exactly whats happening in my physical model.
I am using ANSYS Mesher.
I need different sized layers in different surfaces because my throat is approximately 100 times smaller than the inlet and outlet. So to get enough elements at the throat, the size change is necessary.
I just have hard time figuring out why am i not able to get the same mesh in the two cases shown in the pictures above.
Old   September 25, 2014, 03:49
rather than having smooth transition (which i believe you have done) you can control what you want the thickness of the inflation layer to be. you cant compare the inner side and the outer side as you have done above because the inner side belongs to the same part.
secondly saying it will not represent what is happening in you physical model is an exaggeration. cfd is all about approximation so it would not make a big difference to you simulation.
and check what the software itself has to say about your mesh, you cant judge a mesh by just looking at it and deciding it isn't looking pretty like that. The mesh in its current state would be fine as well depending on what accuracy you want.
Old   September 25, 2014, 11:50
Ravinder Gill
hwet, i am not using smooth layer transition. I am using first layer height.
[ICEM] Quick Question: Inflation Layer Boundary Definitions Omerta ANSYS Meshing & Geometry 5 January 20, 2021 08:54
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 04:11
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
