How to decide the pressure drops and ...
Old   March 19, 2013, 14:33
Default How to decide the pressure drops and ...
Kevin
KAI918 is on a distinguished road
here is a problem, air flows a smooth plates.
how to decide the pressure drops between inlet and exit,
the rate of heat transfer absorded by the flowing air
and the pumping power?
how can i get results from ANSYS?
Thanks a lot!
KAI918 is offline   Reply With Quote
Old   April 3, 2013, 20:08
Default Pressure drop
Ricardo
ricardo.costa is on a distinguished road
You can try to use boundary conditions to get the pressure drops from the results.
For example: Using Total Pressure in the outlet and Airflow in the inlet.
Regards,
ricardo.costa is offline   Reply With Quote
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 3 September 24, 2018 17:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Wall roughness effects on pressure drops Vangol CFX 1 July 12, 2013 07:41
Wall roughness effect on pressure drops Vangol FloEFD, FloWorks & FloTHERM 1 March 20, 2013 05:50
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
