January 14, 2012, 13:11 |
Meshing of road vehicle
Hi
I am meshing the Ahmed's vehicle. I am getting the problem in meshing the high curvature surface at the front portion. Attached are the tin, blocking and snapshots of meshing. Any suggestion? Thanks |
August 19, 2012, 12:05 |
Rep Power: 15 |
Hi, Far!! I suppose you got it but I will tell you how to proceed for other people.
The key is split the ahmed nose by means isoparametric curves, and then you could carry out the right associations: vertex to points and then edges to curves. Ask me if you need further information. Simon Pereira told me this metodology!! =) By the way, do you know how to generate an hybrid mesh with ICEM?? I mean, I am stucked since I don't get an unsteady wake and I think of doing an unstructured mesh in the block behind the car... Any suggestion will be appreciated! |
February 14, 2013, 19:30 |
jason
Rep Power: 15 |
where is the tin file, teh geometry file, otherwise can not help
February 15, 2013, 00:10 |
Here you go.
Files are also here (different versions) http://www.cfd-online.com/Forums/ans...h-quality.html and http://www.cfd-online.com/Forums/ans...mesh-legs.html |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
simulation of Vehicle in actual road conditions | chitkara_robbin | FLUENT | 0 | April 6, 2009 13:19 |
Vehicle CAD Model Meshing | B Bru | Siemens | 5 | June 8, 2007 18:30 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 12:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
