[GAMBIT] Import STEP files and E-mail Session
Like Tree1Likes
  • 1 Post By -mAx-
Old   December 19, 2011, 04:00
Default Import STEP files and E-mail Session
James
VU_Engineer is on a distinguished road
I have exported an assembly as a STEP from ProE, but am having trouble getting the GAMBIT/FLUENT license to recognize the ProE connection.
Would you please:
Import the STEP into a FLUENT5/6 session
SAVE the session
E-mail me file
should take all of 2 minutes
PM me if you can help and I'll e-mail you the files right away
VU_Engineer is offline   Reply With Quote
Old   December 19, 2011, 05:44
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Once you exported your step from ProE, then you don't need any proE connection or whatever.
You just need to import your step file in Gambit. (File/Import/Step...)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 19, 2011, 05:49
James
Translation requires license feature geom-trans.
I get that error when I try to import.
I believe it is because ProE was not installed when GAMBIT/FLUENT was installed.
Old   December 19, 2011, 06:00
-mAx-'s Avatar
Maxime Perelli
no it is because you don't have the geom-trans license.
Send me your step file
I sent you a private message
Old   December 19, 2011, 06:24
-mAx-'s Avatar
Maxime Perelli
Here we are...
Old   December 19, 2011, 06:28
James
looks great, will you e-mail me the GAMBIT file?
Old   December 19, 2011, 06:35
-mAx-'s Avatar
Maxime Perelli
done
let me know, if you don't get the file
Old   December 19, 2011, 06:37
James
maybe someone has an idea....
"ERROR: Unable to read format database (version 2.4.4). The current format is version 2.3.14."
Old   December 19, 2011, 06:38
-mAx-'s Avatar
Maxime Perelli
you have an older Gambit version
update to 2.4.6
Old   February 16, 2012, 22:55
Alejandro
aalexx88 is on a distinguished road
Hi max i have the same problem! can you help me with the geom-trans license?
aalexx88 is offline   Reply With Quote
Old   February 17, 2012, 01:51
-mAx-'s Avatar
Maxime Perelli
send me your step file
Old   February 17, 2012, 02:24
Default Wing
  #12
Alejandro
Ok, its that one
Old   February 17, 2012, 02:48
-mAx-'s Avatar
Maxime Perelli
done
AlaK.stp.zip
aalexx88 likes this.
Old   March 6, 2012, 12:45
Default Pro-E model to Gambit
  #14
Heron
heronmak is on a distinguished road
I wanted to run gambit to my pro-e model but dont really have an idea how to do so. I have created a STEP file of my pro-e model and managed to open it on gambit. Any idea what my next steps should be? do i need to create boundary layers?
Thanks.
I can upload my pro-e model if any1 is kind enough to have a look
heronmak is offline   Reply With Quote
Old   March 6, 2012, 13:09
Ali
Hybrid is on a distinguished road
try IGES or any other format acceptable for Gambit.
Best Regards
Ali
Hybrid is offline   Reply With Quote
Old   June 14, 2012, 04:09
Damir
londam is on a distinguished road
Hi mAx, I'm also having problems with importing geometry due to license issues.
can you please import my geometry as well?
thanks in advance
londam is offline   Reply With Quote
Old   June 14, 2012, 05:15
-mAx-'s Avatar
Maxime Perelli
thanks in advance
I think you forgot something in your export, since it imports only 3 faces
give me your email, the zip file ist greater than the 97kB required
Old   June 14, 2012, 05:17
Damir
londam2405@gmail.com
hmm... maybe it stiched two long faces...
thanks a lot!
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Gambit Step Files Import dg FLUENT 3 October 25, 2005 22:15
Import of Step Files Nakul Prasad FLUENT 5 February 10, 2005 17:03
