[GAMBIT] Stairstep meshing in Gambit
Old   February 20, 2013, 10:11
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
what do you mean with y direction?
If you have 2 size functions, check your max size. Thus if both max sizes are different, Gambit will only take the smallest as reference.
post a picture, and display where is your source
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 20, 2013, 10:42
Kanarya is on a distinguished road
sorry......
Kanarya is offline   Reply With Quote
Old   February 20, 2013, 10:56
Hi Again,
for first size function references are long walls attach. to whole volume(start:1 ,growth rate 1.2, max 3) and for second size function I gave as reference blue face to whole volume(grading in y direction(start:3 ,growth rate 1.2, max 8) )
thanks a lot
Originally Posted by Kanarya View Post
I am new so I could not fine how to get png file from gambit.
can you help me?
thanks very much sorry for that!
Old   February 20, 2013, 11:57
Hi Max,
are you going to help me?
thanks in advance and sorry for disturbing!!!
Old   February 21, 2013, 02:10
-mAx-'s Avatar
Maxime Perelli
are you working with hexa?
If you already meshed edge before creating size functions, then size functions won't have any effect on meshed edge.
Post again a picture with a zoom on the mesh which disturbes you
Old   February 21, 2013, 05:10
thanks for the help...I upload two pics. as you see in the bottom size function is ok but in side is not. I used smaller number only to check! start with 4 growth rate 1.2 max:8 for both direction!
thanks again do you have some suggestion?
Old   February 21, 2013, 07:57
-mAx-'s Avatar
Maxime Perelli
on your second picture we can see a size function, especially on the square surface in background.
but you only diplayed surface mesh.
I would go to examine mesh, and display a slice of the volume mesh to see what's happened inside your volume.
[ANSYS Meshing] ANSYS Meshing vs GAMBIT aerospain ANSYS Meshing & Geometry 0 September 28, 2011 07:05
Gambit meshing error jx FLUENT 11 May 26, 2009 11:35
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 03:02
meshing a fan using gambit tony FLUENT 1 February 15, 2008 01:28
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 20:06
