November 14, 2012, 10:45 |
#21 |
zaynah K.
Rep Power: 14 |
yes i want to.
November 15, 2012, 02:51 |
#22 |
Maxime Perelli
Rep Power: 41 |
only one size function................
Sans titre1.jpg Sans titre2.jpg The only problem is between faces 133 & 139 (a combination of split and connect should fix the issue) Sans titre3.jpg
In memory of my friend Hervé: CFD engineer & freerider |
November 15, 2012, 05:11 |
#23 |
zaynah K.
Rep Power: 14 |
hi..
did as you told and got that error "mesh of face.334 contain 1 highly skewed element" |
November 15, 2012, 05:14 |
#24 |
Maxime Perelli
Rep Power: 41 |
what are your parameters for your size fonction?
November 15, 2012, 05:21 |
#25 |
zaynah K.
Rep Power: 14 |
tet/hybrid, tgrid and 10
November 15, 2012, 05:25 |
#26 |
Maxime Perelli
Rep Power: 41 |
http://aerojet.engr.ucdavis.edu/gamb...ommands_create
I used tet/Hexcore http://aerojet.engr.ucdavis.edu/gamb...chemes_hexcore
November 15, 2012, 05:35 |
#27 |
zaynah K.
Rep Power: 14 |
sorry i misread.
0.03 1.3 1 |
November 15, 2012, 05:51 |
#28 |
Maxime Perelli
Rep Power: 41 |
I used
1 1.2 20
November 26, 2012, 06:05 |
#29 |
zaynah K.
Rep Power: 14 |
hi
did you mesh the faces first? and my PC is quad core with 16 Gb of ram..i still can not mesh it. |
November 26, 2012, 06:08 |
#30 |
Maxime Perelli
Rep Power: 41 |
If I meshed the surface then it is only building's surfaces.
What kind of error do you receive?
November 26, 2012, 06:13 |
#31 |
zaynah K.
Rep Power: 14 |
volume cannt be meshed without faces sucessfully meshed
November 26, 2012, 07:04 |
#32 |
Maxime Perelli
Rep Power: 41 |
then you have skewed cells for sure, check where I pointed out (post #22)
November 26, 2012, 10:08 |
#33 |
zaynah K.
Rep Power: 14 |
i did of course as you recommended for in post#22...
still it says i have skewed elements... sometimes it meshes then all freeze and i have to start again.. |
November 26, 2012, 10:28 |
#34 |
Maxime Perelli
Rep Power: 41 |
go to examine mesh and check where are those cells.
December 6, 2012, 06:38 |
#35 |
zaynah K.
Rep Power: 14 |
dear max,
after i split n connect faces. i then mesh the faces using tri pave then i mesh the volume. attachd is the error i found. can you please enlighten me ? cheers |
December 6, 2012, 06:57 |
#36 |
zaynah K.
Rep Power: 14 |
hi
what to do when we have highly skewed elements? it say my mesh has 63 highly skewed elements...;( thanks |
December 6, 2012, 07:54 |
#37 |
Maxime Perelli
Rep Power: 41 |
fix those skewed elements.
First, check where they are, and try to find any topology which is responsible for the skewness
February 20, 2013, 07:37 |
Gambit size function problem!
#38 |
Rep Power: 16 |
I am trying to use two size function together but it seems doesnt work. my geometry is 3D I would like to have dense mesh y+=1 near the wall and at the same time to have coarser mesh in flow direction. it it seems like I am getting dense mesh near the wall but I got same mesh size in direction of flow. the other problem is gambit giving me problem with the memory! thanks in advance! |
February 20, 2013, 09:14 |
#39 |
Maxime Perelli
Rep Power: 41 |
what parameters did you give for size function?
February 20, 2013, 10:01 |
#40 |
Rep Power: 16 |
[ANSYS Meshing] ANSYS Meshing vs GAMBIT | aerospain | ANSYS Meshing & Geometry | 0 | September 28, 2011 07:05 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 11:35 |
GAMBIT problem with 3D Boundary Layer when meshing | Anthony Haroutunian | FLUENT | 2 | March 26, 2008 03:02 |
meshing a fan using gambit | tony | FLUENT | 1 | February 15, 2008 01:28 |
Gambit: too long meshing time! | delsolman | FLUENT | 1 | January 29, 2008 20:06 |
