January 6, 2011, 16:14 |
Editing Volumetric Mesh Density Help
Brian Henry
Rep Power: 16 |
Hey, all, thanks for reading this.
I have a question about volumetric meshing, in particular, when you create one from an unstructured domain, how can you determine the density of the interior elements so that the quality of the interior shell is ensured its highest quality? I am meshing the CFD space within the spinal cord, and the default volumetric element size is too coarse, and un-exportable into Fluent. Thanks for your help |
January 7, 2011, 18:21 |
Simon Pereira
Rep Power: 47 |
There are several ways... What mesher are you using?
In ICEM CFD, you could set the max size (global setting), or you could create density regions which let you set a max size within a particular volumetric region. |
January 7, 2011, 18:32 |
Brian Henry
Rep Power: 16 |
Thanks for your post.
I use ICEM CFD: Before, when I used to use Gambit you can subdivide a surface face into regions, each becoming a vertex for a volumetric tetrahedron. I found that you can't do that in Ansys. So, you have to do it through sizing? Every time I begin to mesh, it asks me to autosize the mesh. How can I manipulate this so I get as fine an interior mesh as possible? Thanks for your help |
January 8, 2011, 15:18 |
Body of Influence
Simon Pereira
Rep Power: 47 |
In ANSYS Meshing you can go into sizing and create a sphere of influence which centers on an LCS (Create the LCS first so you can select it)... I usually end up stringing several spheres together to create the shape that I want to refine...
Or you can create a body of influence which expects you to select a body... The sides of the body are not capture, it is just used to control the refinement in the volume. It is actually quite powerful because the body of influence can be any shape that you might need. Look up these terms in the help to get more info... |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
