Rep Power: 16 ![]() |
Hi friends,
I have created a mesh for my fan model but there are only one cell zone. Can someone help me to create new zone around an impeller ? Thank you in advance for your time Pichai |
Maxime Perelli
Rep Power: 41 ![]() |
which software?
In memory of my friend Hervé: CFD engineer & freerider ![]() |
Hi Max
I have created mesh in Fluent Workbench |
Maxime Perelli
Ok I can only help you on the Gambit side.
The idea was to split your volume around your impeller.
Thank for your time Max
anyway I have ICEM and CFX mesh too but I don't have Gambit could you help me ? |
Maxime Perelli
I don't see how can I help you...
Simon Pereira
Rep Power: 47 ![]() ![]() |
You can draw a circle in DM and then extrude it thru the volume (around the impeller). You will see options for trim or add material, but there is also one for "cut". There are lots of ways to slice up a body in DM... Maybe find a meshing tutorial that covers this and then apply it to your situation. Look up Slice in the help.
Then create a named selection for each volume so each can come into Fluent as a different fluid volume for easy selection... Simon |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 15:18 |
splitMesh error - point, face or cell zone already exists#0 | nikwin | OpenFOAM | 1 | January 27, 2010 05:31 |
Error during Iteration | anjantula | FLUENT | 0 | January 23, 2010 17:41 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
How to create a Cell Zone | Bikash | FLUENT | 4 | October 26, 2003 16:04 |
