[ANSYS Meshing] Problem in meshing slinky coil burried in the ground |
January 9, 2020, 03:42 |
teguh hady
Rep Power: 18 |
Dear all,
I want to simulate slinky coil ground heat exchanger by Ansys 17.2. The mesh ground is attached sample. The coil diameter is 1 m and pipe diameter is 43 mm. The mesh far from coil is robust and near coil is fine. I just want to simulate one turn due to computational limitations. However, I find mesh problem in near coil ground. I have tried body influence but it is failed. I want to get as good as attached figure. Do you have any suggestions? Thank you best regards Teguh
Now Or Never!!! |
January 17, 2020, 04:00 |
overlapmesh
teguh hady
Rep Power: 18 |
Dear all
I have tried body influence it seems can not work so I divide ground into several parts as interface. Because the size of the coil is small compared to the ground. It makes me easier to mesh. However the problem is overlapping contact region. Do you have any suggestion? Thank you for your help Regrads
Now Or Never!!! |
February 10, 2020, 00:50 |
Alexander
Rep Power: 34 |
if you have conformal mesh,then you dont need contacts
remove contacts
best regards ****************************** press LIKE if this message was helpful |
February 10, 2020, 04:31 |
teguh hady
Rep Power: 18 |
Dear AlexanderZ
I have fixed this issue. Thank you
Now Or Never!!! |
burried coil, ground heat exchanger |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 19, 2023 00:49 |
3D Cyclone meshing problem | Wayne12195 | Mesh Generation & Pre-Processing | 0 | September 25, 2018 02:45 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 06:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 10:22 |
