[ANSYS Meshing] inflation around a cube
Like Tree1Likes
Old   January 19, 2017, 09:01
zeng
zeng1017 is on a distinguished road
Originally Posted by Antanas View Post
Wrong. It's still there.
Hi Antanas,
Nice to receive your reply again. I thought you were referring to the "mapped face meshing", which has an option "radial number of deviations"(please see the picture). This option gives smoother transition around corners(please see the picture), which is similar to the mesh I am trying to do (picture 1).
If you have any idea about how to make this kind of mesh in v171, please let me know. Any help appreciated.
zeng1017 is offline   Reply With Quote
Old   January 19, 2017, 12:49
zeng
Originally Posted by siw View Post
The only way to get the mesh shown in Picture 1 using ANSYS Meshing is to decompose the geometry into 4-sided (if this is 2D) blocks. Unlike ICEM in which you can make the blocking topology at the mesh level, ANSYS Meshing requires this to be done at the geometry level, so for instance smoothing of the mesh across geometry blocks is not possible.
Use DesignModeler or similar to slice your domain into blocks and then you can use edge sizings (with bias if you like).
I have attached a quick test of what I think you want using DesignModeler and Meshing inside Workbench using v17.2. Unzip and then un-archive in Workbench. I have used a MultiBody Part and notice there is no smoothing.
Hi Stuart,
Thanks a lot for your help. I am trying to run the following 3 mesh. The supercomputer is super busy today.
Besides, I still wondering how to generate the mesh similar to "mapped face meshing". This method has an option "radial number of deviations"(please see the picture: https://www.cfd-online.com/Forums/at...e-picture9.jpg). This option gives smoother transition around corners(please see the picture: https://www.cfd-online.com/Forums/at...-picture10.jpg), which is similar to the mesh I am trying to do (picture 1: https://www.cfd-online.com/Forums/at...-picture-1.png).
If you have any idea, please let me know. Any help appreciated.
Old   January 19, 2017, 13:05
siw
Stuart
siw will become famous soon enough
Your three pictures show good meshes of different element layouts, are they still giving solution issues?
zeng1017 likes this.
siw is offline   Reply With Quote
Old   January 19, 2017, 17:12
zeng
Hi Stuart,
I just checked my 3 Fluent jobs running on a supercomputer. only the following meshing gave converged iteration.
(https://www.cfd-online.com/Forums/at...-picture11.jpg)
Another two got diverged. For the divergence of this one,
(https://www.cfd-online.com/Forums/at...-picture12.jpg)
I think it is because the abrupt mesh transition happened on the corners.
For the divergence of another one,
(https://www.cfd-online.com/Forums/at...-picture13.jpg)
I have no idea why it happened. I am trying other p-v coupling methods to see if that will give a better result.
Old   March 12, 2018, 06:18
yanki cob
yanki is on a distinguished road
such an informative thread. thanks for all the answers.
yanki is offline   Reply With Quote
[ANSYS Meshing] Problems with creating a hex-uniform MultiZone Mash with Inflation AnnaF ANSYS Meshing & Geometry 4 April 19, 2019 07:24
Cooling cube in a room John_Major System Analysis 0 July 4, 2015 04:24
[snappyHexMesh] snappyHexMesh on sharp corners (cube) Regis_ OpenFOAM Meshing & Mesh Conversion 0 June 5, 2015 00:47
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 13:11
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 07:29
