[DesignModeler] Problem in filling Surface geometry
Old   June 26, 2016, 13:47
Exclamation Problem in filling Surface geometry
aagam
voldemort is on a distinguished road
I imported a 3D solid Geometry in SAT format in ANSYS Workbench 15.0. It turned out to be hollow in ANSYS, but it was solid in Autocad. I am attaching screenshots 6 & 7 to support my motion.
When I tried to use FILL command on surfaces to fill it and convert to 3D again, it didnt worked out.
It shows following Error : Model Size is out of Range.
How to Rectify this problem?
voldemort is offline   Reply With Quote
[ICEM] Building geometry meshing problem Yatharth Vaishnani ANSYS Meshing & Geometry 1 June 12, 2016 07:33
Problem with surface monitor position jf90cl FLUENT 0 April 28, 2016 12:41
[Workbench] Problem to select facing when updating geometry vbernard ANSYS Meshing & Geometry 1 October 28, 2013 10:18
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
