[ANSYS Meshing] extrude volume in ANSYS Multiphysics |
July 26, 2013, 10:51 |
Nguyen Quang Long
Hello everybody.
I have a problem with ANSYS multiphysics and i need to help. Let say i have 1 circle area, inside this area, i have a smaller square area. I want to extrude the circle area first then call that layer 1, and i want to extrude the square area on top of layer 1 and make sure that box (after extrude) can connect with layer 1. How can i do that? Please help me. Thank you very much |
July 26, 2013, 13:41 |
Sweept mesh of two bodies in contact
Jan
Rep Power: 13 |
Hi.
DesignModeler: You have to split your geometry at the connection area of your two cylinders. After that, you have to define a "Part assembly" (select bodies *right click* "Form new part". Finally, you have to enable the option "Share Topology" to imprint at the interface. ANSYS Meshing: In ANSYS Meshing, you have to define two sweep methods for each body. Thats it. If two bodies are in the same part, ANSYS Meshing will continue at the surface mesh of an existing mesh on such faces, which are shared by both. This results in a mesh with 1:1 connection on the mesh interfaces. I hope, I understood your described problem. Regards, Jan -------------------------------- Jan Smedseng CFX Berlin Software GmbH |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
ANSYS Multiphysics Bearing Simulation | Dimitris | ANSYS | 2 | November 10, 2011 06:17 |
[ICEM] Volume Direction Error in Ansys ICEM | sebastian | ANSYS Meshing & Geometry | 0 | December 15, 2009 10:24 |
