[ICEM] ICEM - Blocking stratergy for simple pipe |
March 13, 2013, 18:37 |
Jimmi
Rep Power: 13 |
Hi all,
I am attempting a structured mesh in ICEM for a simple pipe (parabola with a flat base). I however cannot get the mesh between surfaces correct (second picture), are there any tutorials for pipe flow with external and internal meshes? (if that makes sense!) Also I was generating the mesh on the pipe by deleting blocks (between internal and external surface) and associating edges to surface, I haven't merged any verticies and am stuck with how to map the top. |
March 14, 2013, 10:01 |
You are lucky
March 16, 2013, 07:04 |
#3 | |
Jimmi
Rep Power: 13 |
Many thanks Far, I have attempted (a lot of times!) using o-grid (half and full) hoever I get a similar error each time (volume error) but the volumes appear to be ok (fluent confirms the error though.) I am not sure where I am going wrong with blocking. |
March 16, 2013, 12:42 |
Here is the blocking for you Some adjustments in edge sizing is required. Also move some vertices to make the quality better.
Do you feel like this while working with ICEM Hexa Some images from attached blocking : |
March 17, 2013, 14:40 |
Jimmi
Rep Power: 13 |
Many thanks Far!
I had a look at the mesh and it looks good, I still get volume errors though. I am starting to think it is impossible not to get them! |
March 17, 2013, 14:43 |
March 17, 2013, 15:30 |
March 17, 2013, 16:59 |
#9 |
Jimmi
Rep Power: 13 |
March 17, 2013, 17:36 |
#11 |
Jimmi
Rep Power: 13 |
[ICEM] Structured grid without blocking in ICEM | BahaZero | ANSYS Meshing & Geometry | 19 | March 5, 2013 12:36 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 18:27 |
[ICEM] Using Blocking with ICEM (infinity lines appear) | Touré | ANSYS Meshing & Geometry | 6 | August 5, 2012 18:07 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
