[ICEM] what is the strategy to block this geometry? |
October 8, 2012, 08:07 |
#22 |
Li
Rep Power: 17 |
Hi energy382, the problem is solved. I need to add six surfaces to enclosed it. Thank you.
October 8, 2012, 08:50 |
#23 | |
Christoph
Rep Power: 18 |
No, your blocking is destroyed. Need to do a new one. You've to improve mesh quality (edge parameters, smoothing etc). Don't have time to do this too. Last edited by energy382; October 8, 2012 at 11:05. |
October 9, 2012, 03:34 |
#24 |
Li
Rep Power: 17 |
Hi energy382, thank you for the help. I made the new one yesterday and generate relatively good mesh quality. May I ask why the block is destroyed since I have the same steps to operate the block? I also would like to ask if there should not be any single surface (not closed surface) in the geometry? Thanks a lot.
October 9, 2012, 07:06 |
#25 | |
Christoph
Rep Power: 18 |
Even if you have periodic boundaries (e.g. turbine blade passage), you should at least create a part with a single point within, where you project your faces to. Otherwise, ICEM always project edges to closest surface. Last edited by energy382; October 9, 2012 at 09:46. |
October 10, 2012, 06:54 |
#26 |
Tamil Nadu
Rep Power: 14 |
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT. Can anybody help me out, how to model and simulate? Does any tutorials exist? |
October 10, 2012, 11:20 |
#27 | |
Li
Rep Power: 17 |
October 11, 2012, 09:02 |
#29 |
Christoph
Rep Power: 18 |
I guess, you've forgotten to merge vertices after creating y-grid!?
October 12, 2012, 04:13 |
#30 |
Li
Rep Power: 17 |
October 12, 2012, 04:14 |
#31 |
Li
Rep Power: 17 |
October 12, 2012, 04:54 |
#32 | |
Li
Rep Power: 17 |
(1) split the block (2) merge the vertex (3) create y-block (4) generate the mesh After I create the y-block, should I merge the vertex again? What vertex should I merge? I tried to merge vertex again, but it gives me the information that the vertex is unique. If there is something that I did wrong, please let me know. Thank you. |
October 15, 2012, 10:32 |
#33 | |
Christoph
Rep Power: 18 |
you've to merge the vertices, where the two edges (vertical) of the y-blocks match. compare my blocking with your blocking at this area. |
October 18, 2012, 09:37 |
#34 |
Li
Rep Power: 17 |
Hi energy382, I do the two y-blocks at the same time. I tried to merge the vertex where these two y-blocks meet, but it still gives me the information that the vertex is unique? Is it possible that the vertex already merged when I generate the two y-blocks at the same time? Thank you. BTW, I cannot see your block.
October 18, 2012, 09:48 |
#35 |
Li
Rep Power: 17 |
Hi energy382, the problem has been solved. The mesh is fine. I did not merge the vertexs where the two y-block meets (I generated them at the same time, I could not perform the 'merge vertex' operation at all). Thank you for the help.
[ICEM] blocking strategy for ellipse geometry | gajemon | ANSYS Meshing & Geometry | 6 | April 21, 2014 17:19 |
[ICEM] Copy geometry then copy mesh | Anna Tian | ANSYS Meshing & Geometry | 0 | July 30, 2012 17:59 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 05:25 |
[ICEM] Best way to import geometry ICEM | Cottbus | ANSYS Meshing & Geometry | 4 | June 12, 2012 10:42 |
[ICEM] Ship Hull imported geometry | nuovodna | ANSYS Meshing & Geometry | 0 | February 25, 2010 11:09 |
