[ICEM] Checking the mesh -> problem of single edges
Old   September 22, 2012, 12:35
Cool SINGLE EDGES are Expected for a 2D model
  #21
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
That Single Edges Check is listed under "possible problems", not Errors.
A Single Edge is just an edge of an element that has no other elements attached to it. That doesn't sound so bad does it?
It could be a problem in a 3D model where you want the exterior shells to be closed before you can generate a delaunay fill because it could represent a hole you need to close... In a 3D model, it could also be little tags of mesh that you want to remove (this is what the auto fix assumes).
It is not usually a problem for a 2D mesh (or shell mesh)... You should expect single edges all around your perimeter!
However, if you see internal single edges where you don't expect them, that may be a problem (a gap or connectivity problem).
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 24, 2012, 05:04
Clecl is on a distinguished road
Thank you very much! It reassures me! I have indeed single edges all around my perimeter, and only there.
Thanks a lot!
Clecl is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
