[ICEM] 2D to 3D block by rotation
Like Tree8Likes
Old   July 7, 2012, 14:17
Khayyamian
hadikhayyamian is on a distinguished road
Thanks; so you mean the main remedy in such situation is to ply with vertices and edges regaridng to each other?
hadikhayyamian is offline   Reply With Quote
Old   July 7, 2012, 14:20
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Aligning vertices and edges is the key to good blocking, besides the good blocking topology. But I found some new problems, which are related to how we apply the o-grid. I guess I should apply O-grid for boundary layer mesh first and then the o-grid for the pipe(both inner and outer).
Far is offline   Reply With Quote
Old   July 7, 2012, 14:26
Khayyamian
I myself use block Extrusion for inlet pipe!
Old   July 7, 2012, 14:27
Far
Sijal
me too. After that I applied the O-grid around the pipe inside the main domain and then inner o-grid for the pipe all way to the bottom wall.
Old   September 26, 2015, 17:57
Default 2D to 3D block by rotation
  #25
David
mrkmrk is on a distinguished road
Hi, all.
I´m new in ICEM. I read ICEM tutorials and tried to mesh a simple 3D axisymmetric geometry that is shown in Figure 1. I want to mesh this geometry using 2D to 3D blocking method. Therefore, I meshed the 2D block that is shown in figure 2 and tried to rotate this 2D block to mesh the 3D geometry. The problem is ICEM cannot mesh this geometry using the mentioned method (Figure 3, 4).
Where do you think I am wrong?
mrkmrk is offline   Reply With Quote
Old   September 28, 2015, 01:39
Antanas is on a distinguished road
Originally Posted by mrkmrk View Post
Hi, all.
Associations?
Antanas is offline   Reply With Quote
Old   September 28, 2015, 03:52
David
I have associated 4 vertexes to 4 points that exist on the 2D block corners and 4 edges to 4 curves of the 2D block. based on the some sections of tutorial I thought that face to surface association is not necessary in this case, but it is. Thank you Antanas.
Old   October 1, 2015, 12:15
Far
Sijal
did you follow the procedure in youtube tutorial ?
Old   October 2, 2015, 11:58
David
Hi Sijal,
Yes, It was not helpful.
Old   October 2, 2015, 12:39
Far
Sijal
Hi Sijal,
Thankyou
2d to 3d rotate, blocking, faulty mesh
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 11:01
[ICEM] Quest for seemingly simple Blocking (degenerate block) la7low ANSYS Meshing & Geometry 0 July 12, 2011 20:48
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 14:13
