Verifying adjoint results - Complex step or Finite Difference |
February 4, 2016, 09:16 |
Mandar Kulkarni
Rep Power: 13 |
Dear SU2 developers,
Is there a provision to verify the SU2 adjoint results? Is the Complex Step method implemented in any part of SU2? If not, are there plans for doing so? I am currently performing Finite Difference to check some of the results I am generating. This involves running SU2_DEF to create a new perturbed mesh and then running SU2_CFD to perform analysis of the perturbed geometry. How do the SU2 developers do this? Is there a python script already written? (I am curious because do not want to reinvent the wheel.) Thanks for your help, Mandar |
February 5, 2016, 05:57 |
Tim Albring
Rep Power: 11 |
Hi kmandar,
you can use Finite differences or forward mode of AD to verify the gradient. For FD you can simply use the finite_differences.py script. For Forward mode (or called direct differentation mode) you have to first of all compile the correct binary. Follow the information here: https://github.com/su2code/SU2/wiki/AD-Build Instead of or in addition to --enable-autodiff add the flag --enable-direct-diff. After compilation and setting the correct paths, you can use the script direct_differentiation.py. |
February 5, 2016, 13:37 |
Mandar Kulkarni
Rep Power: 13 |
Hi Tim,
Thanks for your reply. I will try both these options. Mandar |
solving finite journal bearing problem by finite difference | Atit Koonsrisuk | Main CFD Forum | 6 | March 29, 2015 09:09 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
Finite Volume Vs Finite Difference | Mukkarum | Main CFD Forum | 3 | February 8, 2003 12:16 |
Difference in results using different Mesh? | Julie | FLUENT | 7 | July 2, 2002 11:28 |
