Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Optimization objective
Old   May 9, 2014, 16:40
Default Optimization objective
Sreekanth
shsreekanth is on a distinguished road
In the configuration file, there is an option to specify objective function with the scale. Objective functions are drag , lift etc. How does the solver know whether its a minimization or maximization problem.
In my case , i am interested in minimizing the force on an object. So how should the objective function be specified?
Thanks,
Sreekanth
shsreekanth is offline   Reply With Quote
Old   May 15, 2014, 17:13
Sean R. Copeland
copeland is on a distinguished road
Hello Sreekanth,
Generally, objective functions in SU2 are always minimized (there are some exceptions like efficiency). For an example on how to specify a design problem in SU2, visit the TestCases/euler/naca0012 and look at the optimal design settings in the NACA 0012 configuration file provided.
Hope that helps,
Sean
copeland is offline   Reply With Quote
Old   May 16, 2014, 03:11
Sreekanth
Thanks for the reply.
You say there are some exceptions.
1. By default, is "Lift" being minimized or is it maximized?
2. If its being maximized, can i convert it to minimization problem by multiplying with -1 ?
3. Can i have a linear combination, or a ratio of the two terms, say (LIFT + 10* DRAG )? I tried giving like that, but it doesn't work.
Sreekanth
Old   May 16, 2014, 04:10
Trent Lukaczyk
rktchip is on a distinguished road
hey sreekanth,
lift is maximized by default. you can set the scale to be negative to change that --
OPT_OBJECTIVE = LIFT * -1.0
You can't combine objectives here at the moment, tho be sure to explore posing your problem with constraints, like lift constrained drag minimization. You can also take a look inside of shape_optimization.py to see how you can build your own objective functions in python.
rktchip is offline   Reply With Quote
what are the scaling factors of Optimization objective and constraint functions ? mechy SU2 Shape Design 4 September 22, 2017 04:23
Total force optimization or pressure force optimization? robyTKD SU2 Shape Design 1 August 19, 2013 16:54
COMSOL: Setting up simple optimization problem tdh89 COMSOL 1 May 23, 2012 04:55
COMSOL: optimization applied to a laminar flow tdh89 COMSOL 0 April 30, 2012 09:57
How to do Design Optimization in Fluent 13.0? p36288 Fluent UDF and Scheme Programming 1 July 20, 2011 01:37
