February 11, 2013, 11:00 |
SU2 compilation with MPI option
Vincent RIVOLA
Rep Power: 18 |
Dear all,
I downloaded SU2 and managed to compile it in serial mode without problem. On my system I also have OpenFOAM installed. When I try to install SU2 with MPI option, I get de following error: I use the following configuration: ./configure --with-MPI=mpic++ --with-Tecio=/usr/software/tecplot/lib --with-CGNS-lib=/usr/local/lib --with-CGNS-include=/usr/local/include then running make gives me: Code:
Making all in trunk/Common/lib make[1]: entrant dans le répertoire « /home/vincent/SU2v2.0/trunk/Common/lib » if mpic++ -DPACKAGE_NAME=\"SU\^2\" -DPACKAGE_TARNAME=\"SU\^2\" -DPACKAGE_VERSION=\"2.0\" -DPACKAGE_STRING=\"SU\^2\ 2.0\" -DPACKAGE_BUGREPORT=\"susquared-dev@lists.stanford.edu\" -DPACKAGE=\"SU\^2\" -DVERSION=\"2.0\" -I. -I. -I/usr/local/include -DNO_METIS -g -O2 -MT ../src/libSU2_a-config_structure.o -MD -MP -MF "../src/.deps/libSU2_a-config_structure.Tpo" -c -o ../src/libSU2_a-config_structure.o `test -f '../src/config_structure.cpp' || echo './'`../src/config_structure.cpp; \ then mv -f "../src/.deps/libSU2_a-config_structure.Tpo" "../src/.deps/libSU2_a-config_structure.Po"; else rm -f "../src/.deps/libSU2_a-config_structure.Tpo"; exit 1; fi ../src/config_structure.cpp: In constructor ‘CConfig::CConfig(char*, short unsigned int, short unsigned int, short unsigned int, short unsigned int)’: ../src/config_structure.cpp:36:9: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetPostprocessing(short unsigned int, short unsigned int)’: ../src/config_structure.cpp:1978:11: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp:1990:11: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetMarkers(short unsigned int, short unsigned int)’: ../src/config_structure.cpp:2054:13: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetFileNameDomain(short unsigned int)’: ../src/config_structure.cpp:3871:6: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp:3877:6: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp:3882:6: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::UpdateCFL(long unsigned int)’: ../src/config_structure.cpp:3965:12: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetNondimensionalization(short unsigned int, short unsigned int)’: ../src/config_structure.cpp:4500:9: erreur: ‘MPI’ has not been declared make[1]: *** [../src/libSU2_a-config_structure.o] Erreur 1 make[1]: quittant le répertoire « /home/vincent/SU2v2.0/trunk/Common/lib » make: *** [all-recursive] Erreur 1 Code:
~/SU2v2.0 > mpic++ -v Utilisation des specs internes. COLLECT_GCC=/usr/bin/g++ COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper Target: x86_64-linux-gnu Configuré avec: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu Modèle de thread: posix gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) |
February 20, 2013, 03:12 |
Thomas D. Economon
Rep Power: 14 |
Hi Vincent,
Do you also have Metis version 4.0.3 on your machine? If not, could you please install this version and add it to your configure options above (i.e. --with-Metis-lib & --with-Metis-include options)? Metis 4.0.3 can be found here: http://glaros.dtc.umn.edu/gkhome/fsroot/sw/metis/OLD. Metis will need to be linked in at compile time and SU2_DDC will need to be used to partition the mesh before SU2_CFD is called. This process is all automated by using the parallel_computation.py script. Hope this helps! Tom |
February 20, 2013, 09:26 |
Vincent RIVOLA
Rep Power: 18 |
Hi Tom,
Thanks for your reply. However, it still does not work. Here is my configure command: Code:
./configure --with-MPI=mpic++ --with-Tecio=/usr/software/tecplot/lib --with-Metis-lib=/home/vincent/SU2v2.0/trunk/metis-4.0.3 --with-Metis-include=/home/vincent/SU2v2.0/trunk/metis-4.0.3/Lib Code:
Build Configuration Summary: Source code location: /home/vincent/SU2v2.0 Install location: /usr/local Version: 2.0 Compiler: mpic++ Preprocessor flags: Compiler flags: -g -O2 Linker flags: CGNS support: no MPI support: yes Metis support: yes Build SU2_CFD: yes Build SU2_DDC: yes Build SU2_GPC: yes Build SU2_MAC: yes Build SU2_MDC: yes Build SU2_PBC: yes Build SU2_SMC: yes Code:
Making all in trunk/Common/lib make[1]: entrant dans le répertoire « /home/vincent/SU2v2.0/trunk/Common/lib » if mpic++ -DPACKAGE_NAME=\"SU\^2\" -DPACKAGE_TARNAME=\"SU\^2\" -DPACKAGE_VERSION=\"2.0\" -DPACKAGE_STRING=\"SU\^2\ 2.0\" -DPACKAGE_BUGREPORT=\"susquared-dev@lists.stanford.edu\" -DPACKAGE=\"SU\^2\" -DVERSION=\"2.0\" -I. -I. -DNO_CGNS -I/home/vincent/SU2v2.0/trunk/metis-4.0.3/Lib -g -O2 -MT ../src/libSU2_a-config_structure.o -MD -MP -MF "../src/.deps/libSU2_a-config_structure.Tpo" -c -o ../src/libSU2_a-config_structure.o `test -f '../src/config_structure.cpp' || echo './'`../src/config_structure.cpp; \ then mv -f "../src/.deps/libSU2_a-config_structure.Tpo" "../src/.deps/libSU2_a-config_structure.Po"; else rm -f "../src/.deps/libSU2_a-config_structure.Tpo"; exit 1; fi ../src/config_structure.cpp: In constructor ‘CConfig::CConfig(char*, short unsigned int, short unsigned int, short unsigned int, short unsigned int)’: ../src/config_structure.cpp:36:9: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetPostprocessing(short unsigned int, short unsigned int)’: ../src/config_structure.cpp:1978:11: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp:1990:11: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetMarkers(short unsigned int, short unsigned int)’: ../src/config_structure.cpp:2054:13: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetFileNameDomain(short unsigned int)’: ../src/config_structure.cpp:3871:6: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp:3877:6: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp:3882:6: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::UpdateCFL(long unsigned int)’: ../src/config_structure.cpp:3965:12: erreur: ‘MPI’ has not been declared ../src/config_structure.cpp: In member function ‘void CConfig::SetNondimensionalization(short unsigned int, short unsigned int)’: ../src/config_structure.cpp:4500:9: erreur: ‘MPI’ has not been declared make[1]: *** [../src/libSU2_a-config_structure.o] Erreur 1 make[1]: quittant le répertoire « /home/vincent/SU2v2.0/trunk/Common/lib » make: *** [all-recursive] Erreur 1 |
February 20, 2013, 17:26 |
Thomas D. Economon
Rep Power: 14 |
You may want to get a fresh copy of MPI and configure/build it yourself (I am not sure how your mpic++ is configured). For instance, I have had success compiling for parallel runs on my laptop using Open MPI with the GNU compilers. You can find Open MPI here: http://www.open-mpi.org. Let me know if this works...
March 5, 2013, 11:05 |
RDG
Rep Power: 15 |
Hi Vincent,
did you finally get SU2 to compile? I'm experiencing the same problem as you did and I'm not able to make it work. Regards, Ricardo. |
March 7, 2013, 04:02 |
Vincent RIVOLA
Rep Power: 18 |
Unfortunately no, I did not have much time to work on this and since I managed to compile the code on our cluster, it was fine for me.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
