February 11, 2013, 04:57 |
How to simulate changing CG/CB
VKS
Rep Power: 13 |
I am trying to simulate the motion of an underwater vehicle that has a varying Center of Gravity and a varying Center of Buoyancy. The variation occurs when the vehicle reaches a particular depth (for ex, at 0.5m depth, the CG moves forward, and CB moves back). As a consequence of these changes, the vehicle moves in a roughly sinusoidal pattern. Does anyone if this can be modeled in Star CCM+? Specifically, how to model a varying CG/CB, and the consequential motion? Would be deeply grateful for any help. VKS |
February 11, 2013, 08:36 |
Ryan Coe
Rep Power: 16 |
You would need to use the rigid body "6-DOF Model" to do this. You could vary the model's CoG with time using a field function or a user macro.
To change the CoB you'll need to omit the gravity model (no hydrostatic pressure variation in the water column) and instead have user-defined external force that changes with time to reflect the desired CoB location and the proper orientation (always up in the inertial frame).
Ryan |
a case which is very tough to simulate....... | sharonyue | OpenFOAM Running, Solving & CFD | 6 | November 22, 2012 02:20 |
Simulate the wind profile on a wind turbine---> HOW ???? | mohammad | Main CFD Forum | 0 | April 13, 2012 09:16 |
Simulate the wind profile on a wind turbine---> HOW ???? | mohammad | Main CFD Forum | 0 | April 13, 2012 09:07 |
energy changing associated with mass changing | Martin duan | FLUENT | 0 | August 6, 2011 13:42 |
How to simulate spatial changing gravity force | lakeat | OpenFOAM Running, Solving & CFD | 0 | June 8, 2011 16:46 |
