pimpleDyMfoam simulation keeps blowing up
Like Tree15Likes
Old   April 18, 2012, 07:34
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Have you already downloaded the case about my cube linemann posted above?
lovecraft22 is offline   Reply With Quote
Old   April 18, 2012, 07:42
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Use the mergeMeshes command.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 18, 2012, 07:49
kid
cfdkid
kid is on a distinguished road
Yes i did, but since the upper folder roCube/ has no mesh points it does not know what to merge. Where should this command be used and how?
Sorry this is a basic doubt.
kid is offline   Reply With Quote
Old   April 18, 2012, 07:50
lore
I'm a little bit stuck there…
I meshed both the stator and the rotor then I moved back in the case folder and tried to run this:
mergeMeshes Mesh/stator/ Mesh/rotor/
All I got was a 1e-05 within the stator folder… I'll try some other options…
Old   April 18, 2012, 07:57
kid
cfdkid
@linnemann @lore
When i executed same command i got some result i suppose mergeMesh ran successfully but where did it create the files.
Note: I was in Mesh/ folder and executed this command:
mergeMeshes rotor stator
Output**********************
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-0bc225064152
Exec : mergeMeshes rotor stator
Date : Apr 18 2012
Time : 16:21:35
Host : "chandra-desktop"
PID : 2465
Case : /home/chandra/Documents/open-foam/roCube/Mesh
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Master: "rotor" region region0
mesh to add: "stator" region region0
Create Times
Reading master mesh for time = 0
Create mesh
Reading mesh to add for time = 3e-05
Create mesh
Writing combined mesh to 1e-05
patch names:
8
uWall
inlet
outlet
btmWall
fWall
bakWall
cube_patch0
cylinder_region0
patch types:
8
symmetryPlane
patch
patch
symmetryPlane
symmetryPlane
symmetryPlane
wall
wall
point zone names:
0
face zone names:
1
cylinder
cell zone names:
1
cylinder
End
Old   April 18, 2012, 08:16
kid
cfdkid
Hello
Merged mesh was created in rotor/1e-5/polymesh/ folder according to the command i gave i.e "mergeMeshes rotor stator" if i had given "mergeMeshes stator rotor" then the mesh would have been created in stator folder. I suppose the final merged mesh is created in the first folder we give(if this understanding is right).
Then i moved th complete new polyMesh from rotor/1e-5/ folder to upper directory and in paraView it show both the mesh ie cube and AMI.
Is this right people ?
Suggest more clearification .
Is it ready to be run now using pimpleDyFoam?
Old   April 18, 2012, 08:58
lore
Nope, is not enough… there's also a sets folder within polyMesh you won't get this way… don't know where it comes from…
Old   April 18, 2012, 09:18
linnemann's Avatar
Niels Nielsen
you get it from this command.
splitMeshRegions -makeCellZones -overwrite
@kid
No your case is far from ready. You need to manually add the AMI entries in the boundary file and then you have to match all the boundary names in the 0/k,omega,nut,p,U etc files, and set the correct BC types.
Linnemann
Old   April 18, 2012, 11:30
lore
I'm a little bit lost now…
To summarize, one needs to:
1. create to separated meshes, one for the rotor and one for the stator;
2. run mergeMeshes to merge the two. The output of which needs to be copied in your case folder, correct?
3. what about splitMergeRegions? What's that supposed to accomplish? Shall it be run after mergeMeshes in the case directory?
4. what about the boundary file? Does it need to be edited by the user? I always thought it was something generated by openFoam…
Sorry about all of these questions and thank you very much for your time!
Old   April 18, 2012, 12:05
trandrit is on a distinguished road
Hi Foamers,
I have been using OpenFoam for a month now, so i'm quite new in it.
I would like to use OF for the simulation of a centrifugation device.
To begin with a simple 3D case i slightly modified the propeller case so as to simulate a stirrer rotating in a cylinder.
I meshed the geometry with Gambit and used fluent3DMeshtoFoam for the conversion.
As Bcs i put AMI on the faces at the interface between both meshes and walls on remaining faces.
Is the writeInterval variable supposed to have an influence on the simulation's stability?
my simulation blows up as long as i put a writeInterval bigger than the time step.
I could keep it as it is but the amont of data rapidly becomes uncomfortable.
Something must be wrong somewhere but i don't know what.
Could someone help me?
I can upload some files if it can help.
trandrit is offline   Reply With Quote
Old   April 23, 2012, 04:08
kid
cfdkid
@linnemann
splitMeshRegions -makeCellZones -overwrite .This command ran successfully .
After this i tried running pimpleDyFoam but it gives error.
The "ami" patches were named accordingly as you told.
Plz have a look at my case for rotating cube.
And suggest accordingly.
http://db.tt/59ubLm1j
Regards.
Old   April 23, 2012, 04:50
linnemann's Avatar
Niels Nielsen
        type            cyclicAMI;
        nFaces          0;
        startFace       208901;
        matchTolerance  0.0001;
        neighbourPatch  cylinder_region0;
        transform       noOrdering;
the nFaces 0; is most likely the issue here.
This means that there are no face-cells at that BC.
Also this is not a 2D mesh so it must be treated as such.
The inlet has only 1 cell in thickness and the cube/cylinder has 8.
Consider adding cells in the z-dir in the blockMeshDict if you want to run it as a 3D case.
Linnemann
Old   April 23, 2012, 05:13
kid
cfdkid
@linnemann
Well the second part i understood, I need to make same elements on inlet (z direction on each face of Boundary) as on cylindrical ie 8 in z direction.
But the first part i.e nFaces 0;
I have used searchAbleCylinder in snappyhexMesh to build that . What should be done to extract faces? or to overcome this problem?
I had run surfaceFeatureExtract command for stl cube. But this was done before executing snappyHexMesh.
Should i run surfaceFeatureExtract again or is there some other method? ( these were done while generating separate meshes of rotor and stator ie before mergeMeshes) ?
Regards.
Last edited by kid; April 23, 2012 at 05:20. Reason: first second second first (human brain)
Old   April 23, 2012, 05:26
linnemann's Avatar
Niels Nielsen
You have this name in the boundary file for both meshes before you do the mergeMeshes
cylinder_region0
mergeMeshes puts all patches with the same name into one patch.
for it to work you need to rename one of the names in the rotor/stator meshes.
you could rename both to describe what it actually is.
ami1
and the other the name
ami2
this way you will always know that the patches starting with ami is and AMI.
Similar you could name all the other patches based on their BC type. eg. the cube is a wall and naming it "wallCube" would make sense.
also the symmetryPlanes could be named "symFront".
It wont fix you case but it's easier to remember if you have a consistent naming convention.
Linnemann
Old   April 23, 2012, 05:46
kid
cfdkid
@linnemann
Valuable pointer man, going to redo the whole process.
Old   April 25, 2012, 04:04
kid
cfdkid
@linnemann
"splitMeshRegions -makeCellZones -overwrite"
Above command gives error now!!!!!
Folder here:
http://db.tt/dV7qC7xO
ERROR:
roCube$ splitMeshRegions -makeCellZones -overwrite
Exec : splitMeshRegions -makeCellZones -overwrite
Date : Apr 25 2012
Time : 12:20:56
PID : 21327
nProcs : 1
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:2
Writing region per cell file (for manual decomposition) to "/home/chandra/Documents/open-foam/roCube/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/chandra/Documents/open-foam/roCube/0/cellToRegion"
Region Cells
0 88195
1 42145
Region Zone Name
0 -1 domain0
1 -1 domain1
Sizes of interfaces between regions:
Interface Region Region Faces
Reading volScalarField cellToRegion
Reading volScalarField p
AMI: Creating addressing and weights between 30192 source faces and 10688 target faces
--> FOAM FATAL ERROR:
Unable to set source and target faces
From function void Foam::cyclicAMIPolyPatch::setNextFaces(label&, label&, const primitivePatch&, const primitivePatch&, const boolList&, labelList&, const DynamicList<label>&) const
in file lnInclude/AMIInterpolation.C at line 878.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 at cyclicAMIPolyPatch.C:0
#3 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#4 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::AMIInterpolation(Foam::PrimitivePatch<Foam::fac e, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&, Foam::faceAreaIntersect::triangulationMode const&, bool
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
Old   April 27, 2012, 06:08
kid
cfdkid
Hello Again,
Thank you for previous hepls but i suppose a bit more is required.
Tried and tried few questions for you. ( Work is still on to get a rotating cube executed)
1. topoSets // ( source: tutorial/propeller/)
2. mergeOrSplitBaffle or split.// ( source: tutorial/propeller/)
3. splitMeshRegions -makeCellZones -overwrite // ( sorce : linnemann's cubo case here : http://dl.dropbox.com/u/15968063/cubo.tar.gz )
Well, as you can see these three commands above.
Does 3rd command takes care of both 1st and 2nd ie creating "sets" and spliting Baffles? ( where is Baffle in "rotating Cube" though it might be in propeller case)
Or my question should be, what sequence one should use these?
And linnemann did you at all use 1st and 2nd command, as used in propeller? Though i can't locate any suitable Dict file for 1st and 2nd command.
And depending on the above question anyother suggestion?
Regards,
CFDkid
Old   April 27, 2012, 09:33
kid
cfdkid
Hi ,
Please find latest rotating cube case here:
http://dl.dropbox.com/u/70019943/roCube.tar.gz
Work flow for successful commands:
blockMesh
snappyHexMesh
mergeMeshes
changeDictionary
Everything went fine till here, but when i intend to execute Solver , it gives following error.
pimpleDyFoam
Create time
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone region0
Reading field p
Reading field U
AMI: Creating addressing and weights between 0 source faces and 0 target faces
AMI: Patch source weights min/max/average = 1e+300, -1e+300, #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 at cyclicAMIPolyPatch.C:0
#4 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libmeshTools.so"
#5 Foam::AMIInterpolation<Foam::PrimitivePatch<Foam:: face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::AMIInterpolation(Foam::PrimitivePatch<Foam::fac e, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&, Foam::faceAreaIntersect::triangulationMode const&, bool) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libmeshTools.so"
EDIT---------------------------------------------1
Hello Everyone,
With some struggle the solver pimpleDyFoam is running now.
Error was with mesh created for stator. After a bit refinement using sHM it works fine.
Though results are awaitted.
Regards,
CFDkid
Old   May 2, 2013, 05:45
Paritosh Vasava
vasava will become famous soon enough
I am making a simulation for mixing processs with an impeller. I have been following the example describing rotating cube in a flow field. Here is what I did
1. I divided the domain in to two parts: a. Region close to the impeller blades. b. The mixing tank (minus the region described by 'a').
2. Created two meshes.
3. Use mergeMesh operation to merge the mesh.
Now, I have following problem/questions.
1. The method I followed did not generate any AMI. What could be wrong?
2. Is it necessary to have conformal meshes to generate AMI?
3. Is there any separate process/file/command to generate AMI?
vasava is offline   Reply With Quote
Old   May 2, 2013, 09:56
Andreas Wendy
A.Wendy is on a distinguished road
can you upload the case you have created yet. maybe we can help you...
andy
A.Wendy is offline   Reply With Quote
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 05:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
pimpleDyMFoam stability problems cnsidero OpenFOAM Running, Solving & CFD 3 January 29, 2011 13:36
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 15:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 14:02
