How to fix a value in the buoyanPimpleFoam solver?
Old   March 26, 2012, 07:15
Default How to fix a value in the buoyanPimpleFoam solver?
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to add a constant field at the buoyantPimpleFoam (thank to the explicitSetValue feature) ad I did for the buoyantSimpleFoam (see here).
I modified the solver and you can find it attached.
When I try to use it, I get the following error:
lab@lab-laptop:~/Documenti/cases_OF/OF_case10_unsteady1_mod$ buoyantPimpleFoam_Epta
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : buoyantPimpleFoam_Epta
Date   : Mar 26 2012
Time   : 12:14:00
Host   : "lab-laptop"
PID    : 6720
Case   : /home/lab/Documenti/cases_OF/OF_case10_unsteady1_mod
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Calculating field g.h
Reading field p_rgh
Creating field dpdt
Creating field kinetic energy K
Creating field source list from sourcesProperties
Selecting source model type scalarExplicitSetValue
    Source: air_infinite
    - selecting cells using cellSet air_infinite
    - selected 2730 cell(s) with volume 1.2
Courant Number mean: 0 max: 0
PIMPLE: Operating solver in PISO mode
Starting time loop
deltaT = 0.072
Time = 0.072
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 9.37413e-07, No Iterations 33
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 7.89177e-07, No Iterations 32
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 9.68752e-07, No Iterations 23
DILUPBiCG:  Solving for h, Initial residual = 0.00105513, Final residual = 9.73831e-07, No Iterations 13
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4  Foam::hRhoThermo<Foam::pureMixture<Foam::constTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct() in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
 in "/home/lab/OpenFOAM/lab-2.1.0/platforms/linux64GccDPOpt/bin/buoyantPimpleFoam_Epta"
#6  __libc_start_main in "/lib/libc.so.6"
Floating point exception
Could anyone help to solve it?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   March 26, 2012, 11:21
Kent Wardle
kwardle is on a distinguished road
Looks to me like it is dying on the thermo.correct() line after the hEqn solution. Are you sure your initial conditions are correct/valid? For example, have you verified that your setup works with the standard buoyantPimpleFoam without sources?
Other than that, I have no experience with this thermo model so I can't really say much.
Good luck.
kwardle is offline   Reply With Quote
Old   March 27, 2012, 05:54
Samuele Z
Dear Kent, Dear All,
first of all, thanks for answering.
Actually, I did try my case with the standard buoyantSimpleFoam solver and - tough a bit slow - it works.
Now it is a bit different: I've edited my solver (see attached) and I get this error: when I write
    sources.constrain(hEqn);
I get this error:
Date   : Mar 27 2012
Time   : 10:50:08
Host   : "lab-laptop"
PID    : 5316
nProcs : 1
Create time
Reading g
Reading field U
--> Upgrading k to employ run-time selectable wall functions
    Backup original k to k.old
    Writing updated k
--> Upgrading epsilon to employ run-time selectable wall functions
    Backup original epsilon to epsilon.old
    Writing updated epsilon
--> Creating mut to employ run-time selectable wall functions
    Writing new mut
--> Creating alphat to employ run-time selectable wall functions
    Writing new alphat
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Reading field p_rgh
Creating field dpdt
    - selecting cells using cellSet infinite_air
Starting time loop
deltaT = 0.12
Time = 0.12
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 9.76351e-07, No Iterations 43
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 9.9149e-07, No Iterations 41
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 9.41257e-07, No Iterations 27
Ok qui - test 1 (file hEqn.H)
DILUPBiCG:  Solving for h, Initial residual = 1, Final residual = 9.89139e-07, No Iterations 46
Ok qui - test 2 (file hEqn.H)
#0  Foam::error::printStack(Foam::Ostream&)^C
Any idea?
Last edited by samiam1000; March 27, 2012 at 07:02. Reason: I forgot the attachement
Old   April 2, 2012, 05:59
Samuele Z
I still have some problems with the buoyantPimpleFoam_Epta.
It is very strange, since I have done the same modification I did with the steady solver.
When I run it, trying to impose the velocity, I get this error message:
lab@lab-laptop:~/Documenti/cases_OF/OF_case09_steady_vs_unsteady/unsteady_mod$ buoyantPimpleFoam_Epta
Date   : Apr 02 2012
Time   : 10:45:33
Host   : "lab-laptop"
PID    : 4310
Case   : /home/lab/Documenti/cases_OF/OF_case09_steady_vs_unsteady/unsteady_mod
nProcs : 1
Create time
Reading g
Reading field U
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
    Prt             1;
Reading field p_rgh
Creating field dpdt
Selecting source model type vectorExplicitSetValue
Courant Number mean: 0.000552417 max: 5.02789
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Starting time loop
Courant Number mean: 8.24029e-05 max: 0.75
deltaT = 0.0298336
Time = 0.0298336
PIMPLE: iteration 1
buoyantPimpleFoam_Epta: malloc.c:4630: _int_malloc: Assertion `(unsigned long)(size) >= (unsigned long)(nb)' failed.
Aborted
Attached you can find the last version of the solver I modified.
Could you help?
Thanks a lot,
Samuele
Old   April 3, 2012, 06:56
Samuele Z
Here the 2 solvers.
buoyantSimpleFoam works properly, buoyantPimpleFoam doesn't. Any idea?
Thanks a lot,
Samuele
Old   April 3, 2012, 07:31
Retired Super Moderator
Bruno Santos
Hi Samuele,
Unfortunately I'm not experienced enough yet to be able to simply look at a modified solver source code and indicate where the problem might be.
I'm not sure if I would be able to point out the problem with examples cases either... But for other people with a bit more experience, it would be good if you also provided an example case for each solver, so anyone can do some trial-and-error in figuring out what's wrong with it!
Best regards,
Bruno
Old   April 3, 2012, 07:37
Samuele Z
This is the link to my case. I provide only the case that I need to solve using buoyanyPimpleFoam_Epta, since buoyanySimpleFoam_Epta works properly.
Thanks a lot
Samuele
Old   April 3, 2012, 11:42
Kent Wardle
You example case is missing polyMesh/sets and does not run. You have not included a topoSetDict so I am not sure how you are setting this. Seems like you mentioned some way to set this from you cellZone. Please instruct.
Old   April 3, 2012, 11:57
Samuele Z
Ooops, sorry.
Let me upload a new case, then.
As far as topoSetDict is concerned, I do not need it.
In buoyantSimpleFoam_Epta I run (successefully!) the case without that file.
Here you can download the new case.
Thanks a lot,
Samuele
Old   April 3, 2012, 12:12
Kent Wardle
Runs with no problem on my machine. Based on the malloc error you are seeing, probably it is linking to the wrong library somewhere and you need to recompile it. Try to wclean and then wmake again the solver and see if it works.
BTW, I also ran with 8 cores no problems.
Old   April 3, 2012, 12:20
Samuele Z
Sorry,
my solver with this case works because you don't have any source applied.
The point is that when you add the sourcesProperties file in the constant folder something strange happens.
You could try, copying this text in an empty file and saving it as sourcesProperties in the constant folder:
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      sourcesProperties;
air_infinite
    //type            vectorExplicitSetValue;
    type            scalarExplicitSetValue;
    active          true;
    timeStart       0;
    duration        100;
    selectionMode   cellSet;
    cellSet         air_infinite;
    //vectorExplicitSetValueCoeffs
    scalarExplicitSetValueCoeffs
        volumeMode      absolute; //specific
        injectionRate
            //U              (0 0.2 0);
	    h              278000;
Could you kindly try?
Thanks a lot,
Sam
Old   April 3, 2012, 13:18
Kent Wardle
Looks like the problem is with thermo.correct(). Perhaps there is some reason this does not work with sources? Unfortunately I have no experience with this specific class of solvers.
Old   April 4, 2012, 03:55
Samuele Z
Hi Kent and thanks again for answering.
Actually, if you look at the buoyanSimpleFoam_Epta (attached here!), you can see that it is the same and that the sources can work with the thermo.correct.
It's strange: it works with the steady case, but it doesn't with the unsteady.
Does anyone have an idea?
Thanks,
Sam
Old   April 5, 2012, 05:09
Samuele Z
Hey Kent, Hey all,
pardon the question, but what about thermo.correct? Which files are linked to this line and what it does?
Thanks a lot,
Samuele
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 10:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 10:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
