How to simulate problems with rotating motion
Old   July 25, 2011, 14:39
Default How to simulate problems with rotating motion
feiqunali
feiqunali is on a distinguished road
Hello, I am now trying to simulate flapping wing with pitching motion, which need an unsteady solver that can simulate rotating problems. Which solver should I choose and can anybody provide some related case?Thanks a lot!
feiqunali is offline   Reply With Quote
Old   July 26, 2011, 05:31
Stefan
SD@TUB is on a distinguished road
Can you be more precisely about your problem, where you need the rotating motion? I would guess, that you need automatic mesh motion for the rigid flapping wing.
Since you expect moderate motions of your wing than mesh morphing might be an appropriate set-up. There is a simulation of a flapping airfoil with OpenFOAM. Unfortunately, i haven't got the web link right now. Maybe, you will take a look into the OF workshops.
As you mentioned "rotating motion" which is either provided by GGI implementation in 1.6-ext or as a solid body motion called rotatingMotion in 2.0.x! You will find it within src/dynamicFvMesh/* directory of your preferred OpenFOAM version.
/Stefan
SD@TUB is offline   Reply With Quote
Old   July 26, 2011, 09:45
Elvis
elvis will become famous soon enough
you are probably interested on the PHD thesis of Frank Bos.
Numerical simulations of flapping foil and wing aerodynamics, mesh deformation using radial basis functions (RBF).
This research is direct applicable to Micro Air Vehicle design and in Wind Turbines.
The RBF is now part of OpenFoam-extent former OpenFOAM-1.5-dev version
=>http://www.cfd-online.com/Forums/ope...on-solver.html
You can find the PHD-Thesis online http://repository.tudelft.nl/assets/...daa1b2/bos.pdf (size 11MB)
The other interesting things might be based on the PHD-thesis of "Sandeep Menon"
Adaptive Tetrahedral Re-Meshing for Deforming Domains,
http://www.openfoamworkshop.org/6th_...ney_slides.pdf
elvis is offline   Reply With Quote
Old   July 26, 2011, 14:50
feiqunali
The rotating motion is defined by a=a0*sin(2*pi*f*t),a is the angle of attack. Do you mean that I could not simulate such motion in OF1.7.0? By the way, I thought I should use pimpleDyFoam, but I dit not know how to set the boundary condition.
Old   July 26, 2011, 14:51
feiqunali
Originally Posted by SD@TUB View Post
/Stefan
Old   July 26, 2011, 15:01
feiqunali
Thank you! I have read part of Frank Bos's thesis. It is very helpful. However, as mentioned above, I do not know how to set the boundary conditions, there seems no such boundary condition provided in OF to describe such motion.
Old   July 26, 2011, 17:53
Stefan
So you are looking for a prescribed (sinusoidal) mesh motion functionality, contrary to my guess. Depending on your desired motion amplitudes you have to decide, if mesh morphing techniques will not cause much distortion. In doubt you can perform topological mesh changes with GGI.
I am not sure, but i think RBF and GGI indeed are exclusively implemented in 1.6-ext! May someone else could give you more details.
What about the derived boundary conditions like movingWallVelocity, rotatingWallVelocity, etc. May there is one appropriate bc for harmonic oscillation as well.
Old   July 26, 2011, 21:45
feiqunali
Thank you! Maybe I have to install a version of 1.6-ext..
Old   July 27, 2011, 04:27
Elvis
you need OpenFOAM-1.6-ext
https://openfoam-extend.svn.sourcefo...nd/trunk/Core/OpenFOAM-1.6-ext/src/dynamicMesh/meshMotion/ =>RBF
to get your Hands on RBF i would advise you to take the LIVE DVD of the EXTEND version from the openfoam workshop
download from http://rcc.its.psu.edu/ofw6/ofw6_v8.iso
in the tutorials the is some not very sophisticated stuff on RBF but boundary conditions etc. are set there
Old   July 29, 2011, 16:08
Default flapping wing openfoam
Dave Smith
davesmith_01 is on a distinguished road
Hi Guys
Does anyone have any tutorials or cases setup which involve a flapping wing in a moving mesh?
I want to model this but am having a difficult time with boundary conditions and am not sure where they need to be implemented and how the should be implemented for a simple sinusoidal motion (theta=A*sin(2*pi*f*t)).
Also I understand that RBF can be used for this but can openfoam do this in version 1.7 aswell using a different method? I want to use an unstructured grid.
Thanks in advance
Dave
davesmith_01 is offline   Reply With Quote
Old   August 12, 2011, 15:55
sanjay's Avatar
aerosapien
sanjay is on a distinguished road
is it possible to do flapping simulation using STARCCM+ CFD code???
sanjay is offline   Reply With Quote
unsteady ; rotating
Combine non rotating part with rotating parts or not ? teck0516 Main CFD Forum 0 July 16, 2011 14:38
Problems in mesh motion solutor in parallel 4 interDyMFoam. DLC Main CFD Forum 0 November 21, 2009 17:17
Problems in mesh motion solutor in parallel 4 interDyMFoam. DLC OpenFOAM 0 November 21, 2009 09:54
simulate the pithing-plunging motion zxx1107 CFX 0 July 11, 2008 04:16
Rotating mesh motion Js CFX 6 May 18, 2007 03:22
