convergence problem
Old   June 17, 2011, 05:08
Post convergence problem
Gregoire Junqua
gregjunqua is on a distinguished road
Hi there.
I am quite new into modelling but i got a convergence problem as follow DICPCG ask a many iteration. How to make it less?
is improving the grid resolution or lowering the grid resolution could help?
or a better approximation of k and epsilon is the solution?
And all link about it are welcome
Courant Number mean: 0.0750431 max: 0.291312
DILUPBiCG: Solving for Ux, Initial residual = 0.00135266, Final residual = 1.80396e-06, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00114192, Final residual = 1.76496e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.047671, Final residual = 0.00470314, No Iterations 17
time step continuity errors : sum local = 7.64284e-08, global = -2.95465e-10, cumulative = 1.88697e-06
DICPCG: Solving for p, Initial residual = 0.0290166, Final residual = 9.92062e-07, No Iterations 777
time step continuity errors : sum local = 1.58005e-11, global = -3.76457e-14, cumulative = 1.88697e-06
DILUPBiCG: Solving for epsilon, Initial residual = 0.00315981, Final residual = 6.3086e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.0141768, Final residual = 7.62168e-06, No Iterations 1
ExecutionTime = 655.38 s ClockTime = 658 s
gregjunqua is offline   Reply With Quote
Old   June 17, 2011, 05:34
Post hello...
T. Chourushi
Tushar@cfd is on a distinguished road
I think the problem is because of the mesh resolution. I just want to know which type of grid have you used? Is it Unstructured?
If it's unstructured then it's usual you will observe the error, check out with structured if you get the same.
Tushar@cfd is offline   Reply With Quote
Old   June 18, 2011, 01:02
Alan Russell
AlanR is on a distinguished road
Check the mesh quality with checkMesh - you could have problems with skewed cells, etc. If you get good results from checkMesh, you are ready to start working on the solution. First, instead of refining the mesh, I would do the opposite. A coarse mesh lets you get the 'outline' of the solution quickly, and shows if your setup is valid. If you can get a coarse mesh solution to converge, then start refining your mesh.
Good luck,
Alan
AlanR is offline   Reply With Quote
Old   June 20, 2011, 22:14
Gregoire Junqua
Hi thanks for your answers.
What do you mean by unstructured?
My grid got a sinus form...
and my
my grid resolution is around 0.01m
and dT = 0.001;
This is the answer of the checkMesh
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
movingWall 1500 3002 ok (non-closed singly connected)
fixedWalls 1100 2202 ok (non-closed singly connected)
outlet 400 802 ok (non-closed singly connected)
frontAndBack 880000 883002 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 -0.5 0) (11 10 0.1)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (-6.5805e-20 5.32246e-20 -7.18612e-17) OK.
Max cell openness = 1.78614e-16 OK.
Max aspect ratio = 4.0807 OK.
Minumum face area = 0.000237529. Maximum face area = 0.002625. Face area magnitudes OK.
Min volume = 2.37529e-05. Max volume = 2.62471e-05. Total volume = 10.9684. Cell volumes OK.
Mesh non-orthogonality Max: 57.1056 average: 28.6341
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.29563 OK.
Mesh OK.
Today i will do some test by improving the grid and the time resolution hope it would work
Old   June 21, 2011, 01:20
Alan Russell
In your checkMesh, I see an outlet but no inlet, which will cause problems with the continuity equation (conservation of mass). Most of your setup is like the cavity tutorial, except for the outlet. Can you describe what you are trying to model? You will certainly need some kind of inlet if you have an outlet.
Alan
Old   June 21, 2011, 02:37
T. Chourushi
Can you please upload your case file??
Old   June 21, 2011, 03:55
Gregoire Junqua
I don't specify the inlet, i just want a uniform wind field at the boundaries
Moving wall
Moving Wall .................................................. .....................outlet
_.-._.-._.-._.-._.-._.-._.-._.-._-._.-._.-._.-._.-._.-._.-._.-._.|
The ground is a sin function, and i want to view the turbulence around it.
[QUOTEFoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
movingWall
type fixedValue;
value uniform (1 0 0);
fixedWalls
type fixedValue;
value uniform (0 0 0);
outlet
type zeroGradient;
frontAndBack
type empty;
][/QUOTE]
If you need more just ask
Thank you for your interest anyway
Old   June 21, 2011, 04:33
Gregoire Junqua
I had try a lower grid scale as around 0.05m and there is a good convergence
How to explain it? my first guess was more the grid scale is small more the convergence is fast ...
convergence, rans
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
