Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
OpenFOAM V&V
Like Tree5Likes
Old   June 22, 2011, 23:56
Martin Hegedus
Martin Hegedus is on a distinguished road
Interesting, I ran 0 degrees angle of attack on the simpleFoam airfoil2D example and it failed to converge and then ran 2.2e-6 degrees and it converged.
http://www.cfd-online.com/Forums/ope...tml#post313183
Not sure what the story is. Maybe I missed a switch or something. Anyone have an idea?
Martin Hegedus is offline   Reply With Quote
Old   June 23, 2011, 05:17
Felix L.
FelixL is on a distinguished road
Originally Posted by Martin Hegedus View Post
Has anyone done a flat plate analysis with OpenFOAM and converged it to machine zero? (Edit: Oh, at low to high reynolds numbers)
Hello, Martin,
I just did a quick simulation of a test case on a 136x96 CVs structured mesh:
http://turbmodels.larc.nasa.gov/flatplate.html
The Reynolds number based on length "1" is 5e6, I used the SpalartAllmaras turbulence model and the simpleFoam algorithm for solving the coupled, steady state incompressible NS-equations.
It's converged below 1e-8 an the residuals decrease is logarithmic (see attached plot).
As for the numerical settings, those are as follows:
fvSolution:
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-12;
        relTol          0.01;
     U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-12;
        relTol          0.01;
     nuTilda
        solver          PBiCG;
        tolerance       1e-12;
        relTol          0.01;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
     residualControl
        p               1e-8;
        U               1e-8;
        nuTilda         1e-8;
relaxationFactors
    default         0;
    p               0.3;
    U               0.7;
    nuTilda         0.7;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,nuTilda) Gauss linearUpwind grad(nuTilda);
//    div(phi,U)      Gauss upwind;
//    div(phi,nuTilda) Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
    laplacian(1,p)  Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
If you have further questions, feel free to ask.
Greetings,
Felix.
Ivanet and FrankFlow like this.
FelixL is offline   Reply With Quote
Old   June 23, 2011, 05:57
Martin Hegedus
Thanks, can you post the input decks for the state variables? I'm interested in knowing the boundary conditions you used.
Old   June 23, 2011, 07:59
Felix L.
You're welcome.
Of course, I will add the boundary conditions later when I come home from work.
So far I can tell you:
INLET:
U: fixedValue (1 0 0)
p: zeroGradient
nuTilda: fixedValue 5e-7 (i guess...)
nut: calculated
OUTLET:
U: zeroGradient
p: fixedValue 0
nuTilda: zeroGradient
nut: calculated
WALL:
U: fixedValue (0 0 0)
p: zeroGradient
nuTilda: fixedValue 0
nut: fixedValue 0
TOP and BOTTOM (in front of the plate):
all: symmetryPlane
I used 2e-7 as viscosity to achieve a reynolds number of 5e6 with the specified inlet velocity.
Greetings,
Felix
Old   June 23, 2011, 13:44
Felix L.
Here are the BC files, as promised.
U:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1 0 0);
boundaryField
    "(bottom|top)"
        type            symmetryPlane;
    outlet
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           $internalField;
    plate
        type            fixedValue;
        value           uniform (0 0 0);
    "(front|back)"
        type            empty;
p:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    "(bottom|top)"
        type            symmetryPlane;
    outlet
        type            fixedValue;
    inlet
        type            zeroGradient;
    plate
        type            zeroGradient;
    "(front|back)"
        type            empty;
nuTilda:
FoamFile
    version     2.0;
    format      ascii;
    object      nuTilda;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 5.0e-7;
boundaryField
    "(bottom|top)"
        type            symmetryPlane;
    outlet
        type            zeroGradient;
    inlet
        type            fixedValue;
    plate
        type            fixedValue;
        value           uniform 0;
    "(front|back)"
        type            empty;
nut:
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
boundaryField
    "(bottom|top)"
        type            symmetryPlane;
    "(outlet|inlet)"
        type            calculated;
    plate
        type            fixedValue;
        value           uniform 0;
    "(front|back)"
        type            empty;
Ivanet likes this.
Old   June 23, 2011, 18:52
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Martin, threads I was referring to are:
SimpleFoam convergence problems
Comparison of axisymmetric case, Starccm+ and OpenFOAM
nevertheless today I found this one:
Convergence
where Henry W. explains the topic about p residuals stagnation, in post #2 he states:
"We don't normalise the residuals the same way as other codes and one consequence is that p may appear not to converge adequately. However, we find that so long as U has converged well it doesn't matter that the p residual is higher. The best thing is to look at the way the fields are evolving."
Problem isn't clear for me, though.
Regards
Tushar@cfd likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   June 23, 2011, 20:01
Martin Hegedus
Convergence
Regards
Yes, there are different ways of determining residuals, one can use the L2-norm of the state vector or the right hand side vector. If the L2-norm of the RHS is used, then it can be used in it's raw form or normalized to represent how the solution marches forward for a local time step or constant time step method.
However, if something isn't clear to so many people, then there might be a problem. I know, OpenFOAM has been used by a lot of people and one would expect this issue to be taken care of in the past... So the problem isn't clear for me either. If I didn't know that so many people used the code for such a length of time, from past experience developing my own codes, I'd say there is a good chance there is a bug in the code. Sadly, I have a lot of experience with bugs, more than I want! Thus the strong need for V&V.
However, on this thread FelixL presented residuals that went past 1.e-8 and seemed to keep going. Given that the airfoil2D case residuals, except at zero angle of attack, fell to the region of 1.0e-10 to 1.0e-12, I suspect that FelixL's flat plate will bottom out at 1.0e-12 or a little past that, probably 1.0e-13. Therefore it seems that 1.0e-6 is not machine zero for OpenFOAM.
For the airfoil case I ran 8, 4, 2, 1, 0.5, 0.01, 0.001, 2.2e-6, and 0 degrees angle of attack. For angles of attack greater than 0.01, the residuals dropped below 1.0e-10. Angles less than 0.01 will be a little different because of the fine vertical grid spacing at z=0 and the fact that the wake must exit the back end. There will be a little bit of a convergence battle going on there. However, that does not explain the jump in residual from an angle of attack of 2.2e-6 to 0.
Old   June 23, 2011, 20:21
Martin Hegedus
Thanks for the decks. I'm trying to compile OpenFOAM 2.0 now and ran into "calls to overloaded 'XYZ' is ambigous' errors. I guess I'll need to update my version of gcc.
Can you do me a favor and run your flat plate case with the top farfield B.C. as freestream rather than symmetry? If you don't have the time, I understand.
The numerics of the freestream and symmetry boundary are somewhat similar in the sense they both impose a value of p and tangential velocity (which should be somewhat similar since the boundary is sufficiently far away) and the normal velocity is 0. The idea is to see if the airfoil2D issue shows up.
Old   June 24, 2011, 03:21
Felix L.
Good morning, everyone,
I'm making this quick, will comment later.
I ran the test Martin requested using freestream as the top boundary condition. My experience with this BC isn't really good so I tend to avoid it. The plot below shows, that the pressure-residuals stall at about 1e-5 and the other residuals stall later as a consequence of that.
Greetings,
Felix.
Old   June 24, 2011, 03:49
Martin Hegedus
Originally Posted by pbohorquez View Post
Nice thoughts. The flat plane analysis is a good suggestion. If someone knows the answer please share it.
With respect to the shear stress in the cell, figure 16 in Alves, Oliveira & Pinho (2003), www.fe.up.pt/~fpinho/pdfs/ijnmf1.pdf, came to my mind. I don't know if it is a crazy idea but iterations in SIMPLE are analogous to "pseudo-time", so maybe there is some analogy between the asymptotic values for the pressure and for \tau_{xx}.
Patricio, when you ran your bullet case, what did you use as your outer boundary condition? Freestream at zero angle of attack?
Old   June 24, 2011, 04:03
Martin Hegedus
Greetings,
Felix.
Thanks. I assume, based on the 2D airfoil case, if you gave it an epsilon of w velocity it would converge. There is also the possibility that if you set the plate to symmetry the case still would not converge, assuming the interior was initialized to something other than freestream. If the code worked correctly it should converge to freestream.
I have no idea why the code is doing this, other than to say there is a bug.
Old   June 24, 2011, 04:27
Felix L.
Good morning, Martin,
at first let me comment on your post #28:
This is not entirely correct. The freestream boundary condition doesn't set a velocity value tangential to the boundary - basically it just works like an inletOutlet-BC for the velocity (and scalars other than pressure) and zeroGradient for pressure.
It means: when the flux vector at the boundary points inwards, the velocity is set to a fixed value of freestreamValue and the pressure is set to zeroGradient. If the flux vector points outwards, it's vice versa.
According to your experiences there might be an explanation: if the freestream velocity is parallel to the boundary (like in my flat plate case), the flux vector component normal to the boundary is zero. This could be causing all this trouble getting the residuals down to machine precision. This might actually explain why it's working for you when you set a slight velocity component in boundary normal direction. Or is the domain of your airfoil case circular?
Greetings,
Felix.
Old   June 24, 2011, 05:07
Martin Hegedus
Interesting, I didn't realize. So instead one should use fixedValue for actually setting the B.C. values to freestream conditions?
Greetings,
Felix.
The airfoil2D case is the one supplied with OpenFOAM. Its a C grid. So, yes, it's got the same condition as the flat plate outer B.C.
Is the switch for in/out for the freestream B.C. based on the local normal velocity or the freestream normal velocity component, i.e. Vinf dot n? The plate example should be forcing the flow outward by a small amount, granted very small.
Old   June 24, 2011, 05:18
Felix L.
It is common practice to set U, nuTilda, k, epsilon etc. to fixedValue and pressure to zeroGradient everywhere where the flux vector is expected to point inside the domain. Accordingly, U, nuTilda, and so on have to be set to zeroGradient and pressure to a fixedValue everywhere where the flux vector points outside the domain.
Problem is, sometimes (e.g. when you have a vortex shedding problem) you might have regions with inflow at the outlet. That's where the inletOutlet BC comes in handy.
As far as I know, the switch for in/out is determined by the freestream velocity. So the velocity vector should be tangential at the top boundary at my flat plate test case, no outward flow there (i.e. same as symmetry). But to confirm that I would need to check the results which I can't access right now.
Greetings,
Felix.
Old   June 24, 2011, 10:39
Patricio Bohorquez
pbohorquez is on a distinguished road
I employed slip and zeroGradient BCs for velocity and pressure fields, respectively.
pbohorquez is offline   Reply With Quote
Old   June 24, 2011, 12:14
Patricio Bohorquez
A better convergence result was found by eliminating the outer domain (which was aligned with the free stream) and by replacing it with a hemisphere. Then, setting as inlet (outlet) boundary condition fixedValue (zeroGradient) for velocity and zeroGradient (fixedValue) for pressure, I reached machine zero.
Old   June 24, 2011, 16:14
Martin Hegedus
I messed up describing the outer boundary for the airfoil2D case. It is a box with the inlet being the front, top, and bottom sides. Not a C grid. The back side is the outlet.
I changed the inlet condition to a wall and set the values (fixedValue) to the freestream values. It converged. Plot is shown below.
I then took the case above and set the pressure to zero gradient for the inlet boundary, and that converged to.
I then wanted to set the front face to freestream V and zero gradient pressure and the top and bottom to freestream p and zero gradient V, unfortunately I didn't have the time to extract the front face from the inlet boundary. The cell faces for the front face are not a continuous set.
Old   June 24, 2011, 16:36
Martin Hegedus
Thanks for all the input.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
