[mesh manipulation] makeAxialMesh and axisymmetric flow
Old   May 31, 2011, 06:54
Default makeAxialMesh and axisymmetric flow
m
yassepid is on a distinguished road
I want to use the makeAxialMesh to create axisymmetric mesh
I compile the makeAxialMesh without error but my problem is that when I want to Run the Axialcavity testcase first I Run blockMesh then I Run makeAxialMesh -axis movingWall -wedge frontAndBack the mesh successfully is generated in folder 0.00125 then I RUN icoFoam without error but when I Run paraFoam I encounter bellow error
--> FOAM FATAL IO ERROR: keyword frontAndBack_pos is undefined in dictionary
"/home/ami/OpenFOAMŪ/ami-1.7.1/run/AXIALRUN/cavity/0.5/p::boundaryField" file: /home/ami/OpenFOAMŪ/ami-1.7.1/run/AXIALRUN/cavity/0.5/p::boundaryField from line 26 to line 34. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 456.
FOAM exiting
I think the reason of this error is that frontAndBack_pos and frontAndBack_neg are not exist in P and U that generated by icoFoam
please help me to run this axisymmetric testcase
yassepid is offline   Reply With Quote
Old   May 31, 2011, 14:11
Assistant Moderator
Bernhard Gschaider
FOAM exiting
Usually the best practice is that once you're sure that the mesh looks the way you want it to move it to constant/polyMesh. Having two meshes at different timesteps only causes confusion (unless you're doing moving mesh of course) If you're confident that makeAkialMash does everything you want it to you can have it write the mesh to t=0 with the -overwrite command line option.
Of course you'll have to adapt the fields to have all the patches that the mesh does (makeAxialMesh doesn't do this for you).
Bernhard
Old   June 1, 2011, 03:30
Default Dear Bernhard
Yasser Amini
aminiyasser is on a distinguished road
Bernhard
Dear gschaider
I Run the makeAxialMesh -axis movingWall -overwrite -wedge frontAndBack
then I run paraFoam
the mesh is corrected.
and after it I run
collapseEdges "2e-07" 5 -overwrite
but when I run icoFoam the flow filed not solved and U=0 for all time !!!!!!!!!!!
please help me
Best Regards
Yasser
aminiyasser is offline   Reply With Quote
Old   April 24, 2013, 02:27
Yasser Amini
Originally Posted by aminiyasser View Post
Dear gschaider
then I run paraFoam
and after it I run
please help me
Best Regards
Yasser
then I run paraFoam
and after it I run
Old   April 24, 2013, 21:01
Assistant Moderator
Bernhard Gschaider
then I run paraFoam
and after it I run
Sounds like a problem with the boundary conditions. Check those
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 28, 2024, 23:38
Default which version of openfoam are you using? does OpenFOAM 5.0 able to use this utility?
cindyhere is on a distinguished road
FOAM exiting
Hi,yassepid.
Good day.
I am currently trying to test the case with makeAxialMesh but failed to compile it.
I've already extracted the tar.gz file and put it under/application/utilities/mesh/manipulation.
then I entered the makeAxialMesh file with Make as subfile, and run wmake but it returned me with this error:
make: *** [makeAxialMesh.dep:337: Make/linux64GccDPOpt/makeAxialMesh.o] Error 1
while compiling OpenFOAM 2.0.0 it returned me errors as well though I was able to compile it.
Please advise me on this, thank you in advance.
Regards,
Cindy
cindyhere is offline   Reply With Quote
[Other] Installing makeAxialMesh - strange wmake error krzychu111 OpenFOAM Community Contributions 1 December 19, 2018 19:29
Swirl component in inflow BC for 2d axisymmetric flows vishalsacharya OpenFOAM Pre-Processing 2 November 2, 2018 06:33
MapFields to Axisymmetric Mesh adkar Main CFD Forum 0 February 15, 2016 06:11
snappyHexMesh axisymmetric multiRegion Henning86 OpenFOAM Running, Solving & CFD 0 October 23, 2014 13:05
Convertation axisymmetric cases from Fluent to OpenFOAM Svensson OpenFOAM 0 April 19, 2011 07:08
