Write the cell area of a patch
Old   January 28, 2011, 05:11
Default Write the cell area of a patch
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
I am using the sample Dictionary to get the value of the color function alpha1 (using interFoam) on a particular patch (wall for my problem). Is possible to let OF prints not only the value of the color function but also the area of the surface (in m^2) for each cell on the patch wall??
I did not need the area of all cells but only those that are on the patch wall..
Thanks
Andrea
Andrea_85 is offline   Reply With Quote
Old   January 28, 2011, 05:30
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
const scalarField& Ap = mesh.magSf().boundaryField()[i];
scalar patchArea = sum(Ap);
niklas is offline   Reply With Quote
Old   January 28, 2011, 05:41
Andrea Ferrari
Thanks for the quick response niklas. Sorry but i'm very new user on OF...where i have to put those line? and how can I specify the patch (wall for my problem) on which I want to calculate the area?
thanks
andrea
Old   July 21, 2011, 11:46
Claudio
claco is on a distinguished road
Dear All,
I would like to know if there is a C++ script (also a piece of code, or the post of the needed code lines would be appreciated) that can allow me to store in a file the coordinates of cell centres along with the areas of each cells, for every patch (or the one user specified) of my mesh. In fact, I need these informations for post processing purposes.
I thank You in advance.
Yours Sincerely.
Claudio
claco is offline   Reply With Quote
Old   July 21, 2011, 12:31
Andrea Ferrari
Hi Claudio,
For the cell centres i guess that you can simply use writeCellCentres
(under OpenFOAM/OpenFOAM-1.7.1/applications/utilities/postProcessing/miscellaneous/writeCellCentres). You will get the coordinates of the centers of all the mesh cells, including cells close to the boundary.
Then, if "areas of each cells, for every patch" means areas of each FACES that belong to a patch, take a look here (post #21)
http://www.cfd-online.com/Forums/ope...tml#post297002
Hope this help
best
andrea
Old   July 27, 2011, 09:29
Claudio
Thank You Andrea. It was just what I needed.
I have another question for you.
I would like to split cyclic patches in OF 1.7.1, in order to have two patches, namely patch_half0 and patch_half1, like can be done in OF 2.0.0.
Is there an utility to do so, in Openfoam 1.7.1?
As a matter of fact, when I try to calculate mass flow rate trough a cyclic patch in OF 1.7.1, the command "patchIntegrate phi cyclic_patch" returns me a near 0 value, whereas the same command given in OF 2.0.0 ("patchIntegrate phi cyclic_patch_half0") returns me a non zero (and correct) value.
Thank You in advance.
Claudio
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 21:05
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
cell surface area in boundary.. Chiar FLUENT 0 March 7, 2007 04:53
How to calculate the cell area Le FLUENT 0 February 18, 2007 23:15
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
