December 14, 2010, 18:30 |
BC on internal patch in laplaceFoam
Mirko Vukovic
Rep Power: 17 |
I have a geometry that consists of two blocks that I build and mesh using blockMesh. I have defined two interface patches, and merged them. I want to solve for the temperature distribution using laplaceFoam. I get an error because laplaceFoam needs a boundary condition on the interface patch. I typed in `xyz' in the 0/T boundaryField dictionary, and I saw a list of available boundary conditions. I did not see anything that would give me a continuous heat flux across the boundary. Do I need to implement my own boundary condition, or am I missing a boundary that can do the job? Thanks, Mirko |
December 15, 2010, 09:34 |
David Boger
Rep Power: 17 |
Do you need the interface? In other words, having "merged" the two blocks together (using stitchMesh or mergeMesh), shouldn't the interface patches vanish altogether?
David A. Boger |
December 15, 2010, 11:53 |
#3 | |
Mirko Vukovic
Rep Power: 17 |
Mirko |
December 15, 2010, 12:44 |
David Boger
Rep Power: 17 |
The discussion in 5.3.2 says "if all the faces of a patch are merged, then the patch itself will contain no faces and is removed", so it sounds to me like something went wrong with the merge.
David A. Boger |
December 15, 2010, 13:31 |
#5 | |
Mirko Vukovic
Rep Power: 17 |
here are the point definitions for the internal patches. They are identical: Code:
(0 0 4.0) // 4 (1 0 4.0) // 5 (1 1 4.0) // 6 (0 1 4.0) // 7 (0 0 4.0) // 8 (1 0 4.0) // 9 (1 1 4.0) // 10 (0 1 4.0) // 11 Code:
blocks ( hex (0 1 2 3 4 5 6 7) (1 1 20) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (1 1 100) simpleGrading (1 1 1) ); Code:
patch interface1 ( (4 5 6 7) ) patch interface2 ( (11 10 9 8) ) Code:
mergePatchPairs ( ( interface1 interface2 ) ) Thanks, Mirko |
December 15, 2010, 14:32 |
Mirko Vukovic
Rep Power: 17 |
I am adding the mesh view.
One block is with a coarse mesh, and the other with a fine mesh along z (this is a 1D geometry) The merged patch is shown by the diagonal lines. Not sure why that is so. I also built the mesh with the blocks not touching, and faces unmerged, to make sure that the blocks are defined OK. Things looked fine. Mirko |
December 15, 2010, 14:46 |
David Boger
Rep Power: 17 |
Without having checked the rules, what if you specify interface2 as (8 11 10 9), so that both interfaces begin from the same point in space?
David A. Boger |
December 15, 2010, 16:29 |
Mirko Vukovic
Rep Power: 17 |
No difference.
For what it's worth, I think that the mesh is valid. If I specify the slip boundary condition on the interface, the calculation runs, and I get an answer that makes sense: the temperature is uniform in each block, the value corresponding to the boundary condition on the far wall. See attached picture. |
December 15, 2010, 16:43 |
#9 |
Mirko Vukovic
Rep Power: 17 |
I think I found the problem:
I am solving a 1D problem and I set the mesh size in the ignored directions to be 1x1. If I change that to 1x2, 2x1, or 2x2, the internal patch is removed, and I get a temperature ramp as expected. Mirko |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 13:46 |
[mesh manipulation] Using createPatch in place of couplePatches | sripplinger | OpenFOAM Meshing & Mesh Conversion | 8 | November 13, 2009 08:14 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 03:34 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
