OpenFoam 1.6-ext
Like Tree1Likes
Old   December 19, 2010, 05:35
Peter_600 is on a distinguished road
Hi boger.
For 'which qmake' I get /usr/bin/qmake. What do you mean by I need 'setenv QT_BIN_DIR /usr. Shall I write it in the console? If yes, I doesn't work. I don t have setenv (opensuse 11.3). I looked for it in the respiratory, but I couldn't find it, nor in the net
@pcaron
I know about this issue, I did one week ago. Yesterday, I have downloaded 1.6-ext again and the Allmake.stage4 seems to differ slightly. Correct me if I am wrong.
Cheers
Peter
Peter_600 is offline   Reply With Quote
Old   December 19, 2010, 11:44
ok, I figured out that setenv doesn t work for bash shell, so I switched to csh. When I write 'setenv QT_BIN_DIR /usr' in the csh shell nothing happens. Still not able to compile paraview. I checked the last Allmake.stage4 file and indeed it changed. There is now an if statement for the qt files. I do not want to compile it again since I have qt installed on my system. I really don t get it to set environmental variables properly.
Old   December 19, 2010, 12:54
David Boger
boger is on a distinguished road
I'd go back to your bash shell and add
export QT_BIN_DIR=/usr
to your .bashrc file, which sets the environment variable QT_BIN_DIR. After that, open a new terminal window (to be sure the environment variable gets added) and try your stage4 again. If it doesn't work, please let us know exactly what error message you get.
Out of curiosity, which version of Qt do you have? ("qmake --version" should tell you.)
David A. Boger
boger is offline   Reply With Quote
Old   December 19, 2010, 13:06
I still get the same output as before, that the environmental variable QT_BIN_USR is not set properly
This system rpm command: rpm
Starting ThirdParty AllMake: Stage4
Using system installed QT
WARNING:
WARNING: Skipping the installation of ParaView-3.8.1.
WARNING: Please make sure the QT_BIN_DIR environment variable properly
WARNING: initialized in the file prefs.sh or prefs.csh
WARNING: The command $QT_BIN_DIR/qmake needs to be valid
WARNING:
Done ThirdParty AllMake: Stage4
my version is:
QMake version 2.01a
Using Qt version 4.6.3 in /usr/lib64
Peter
Old   December 19, 2010, 13:23
David Boger
I'm sorry: try
export QT_BIN_DIR=/usr/bin
David A. Boger
Old   December 19, 2010, 13:28
Here we go
Thank you very much!!!!
Now it s compiling. I let u know about my progress.
Old   December 19, 2010, 13:34
Unfortunately an error occurred
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
QT_QTWEBKIT_INCLUDE_DIR (ADVANCED)
used as include directory in directory /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/GUISupport/Qt
used as include directory in directory /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/GUISupport/Qt/Chart
used as include directory in directory /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/VTK/GUISupport/Qt/Testing/Cxx
-- Configuring incomplete, errors occurred!
error: Bad exit status from /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.2uaRsa (%build)
RPM build errors:
Installing package: ParaView-3.8.1
Uninstalling ParaView-3.8.1 using RPM: ParaView-3.8.1-linux64GccDPOpt.x86_64
Installing ParaView-3.8.1 using RPM file: /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.8.1-linux64GccDPOpt.x86_64.rpm
error: open of /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.8.1-linux64GccDPOpt.x86_64.rpm failed: Datei oder Verzeichnis nicht gefunden
Done installing package ParaView-3.8.1
Old   December 19, 2010, 14:27
Installing 'libQtWebKit4-32bit' solved that problem.
Old   December 20, 2010, 08:43
Pablo Caron
pcaron is on a distinguished road
Hi Peter, I agree with you the script is slightly different. I recopiled 1.6-ext yesterday using an updated git version. To enable the ThirdParty Qt, as I did before, you must set a new variable. I typed this before execute stage4 script.
export  QT_THIRD_PARTY=1
Then I could compile ThirdParty-QT. But you find out how to use the system QT, so I think this info is not relevant now
Regards
Pablo
pcaron is offline   Reply With Quote
Old   December 20, 2010, 12:05
I have some troubles compiling Openfoam. Which compiler version do u use of gcc. Do you use ur system compiler or one from the ThirdParty package?
cheers
Peter
Old   December 20, 2010, 12:11
David Boger
It is always better to tell us exactly what "troubles" you have run into. Do you get an error message?
Whether or not you can use your system version of gcc probably depends most on what version of gcc you have on your system. What does "gcc --version" tell you?
David A. Boger
Old   December 20, 2010, 12:35
for foamInstallationTest, I got this
PHP Code:
WARNINGgcc version does not match gcc supplied with this release of OpenFOAM
         Supplied version
4.3.3
         User version
4.5.0
         Minimum required
4.3.1
gcc      4.5.0
WARNING
:  Conflicting installations:
OpenFOAM settings        : /bin/gcc
          current path
: /usr/bin/gcc
          CRITICAL ERROR
Unfortunately I ve deleted openfoam already. I am going to compile everything again. But it had same warnings concerning paraview, that some variables haven t been set properly.
What is the best way to save the output? when I simply write .Allwmake > log, i don t save all the output from the screen in it. Any suggestions.
Sorry for the poor error message. I will compile it again and change to compiler set by OpenFoam.
Old   December 20, 2010, 12:45
David Boger
Didn't we already discuss this same point in a previous post? The warning you got looks like just that to me - a warning. Based on that warning, there was no reason to delete OpenFOAM.
Maybe it depends on the shell, but something like "Allwmake >& log" or "Allwmake |& tee log" should save the error messages that are written to stderr.
David A. Boger
Old   December 20, 2010, 16:54
I recompiled everything. OpenFoam is running, paraview and paraFoam,too.
Nevertheless, I am no able to see something when I load a case (icoFoam). In the end of stage4 I got an error. Maybe this could be the reason. I don t know how to treat it..
Checking permissions and ownerships - using the permissions files
/tmp/Check.perms.Lf6sJN
setting /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/ParaView-3.8.1-linux64GccDPOpt.x86_64/ to root:root 0755. (wrong owner/group peter:users)
setting /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/ParaView-3.8.1-linux64GccDPOpt.x86_64/home/ to root:root 0755. (wrong owner/group peter:users)
+ /usr/lib/rpm/brp-compress
+ /usr/lib/rpm/brp-symlink
ERROR: link target doesn't exist (neither in build root nor in installed system):
/home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt4/include -> /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/include
Add the package providing the target to neededforbuild and Requires
/home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt4/bin -> /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/bin
/home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt4/lib -> /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/lib64
INFO: relinking /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/ooo3/share/uno_packages/cache/uno_packages/EK5oTh_/mysql-connector-ooo.oxt -> /usr/lib64/ooo3/share/extension/install/mysql-connector-ooo.oxt (was /usr/lib64/ooo3/share/extension/install/mysql-connector-ooo.oxt/)
Processing files: ParaView-3.8.1-linux64GccDPOpt.x86_64
Finding Provides: /usr/lib/rpm/find-provides ParaView
Finding Requires: /usr/lib/rpm/find-requires ParaView
Finding Supplements: /usr/lib/rpm/find-supplements ParaView
Provides: libAnalyzeReader.so()(64bit) libAnalyzeWriter.so()(64bit) libCosmo.so()(64bit) libH5PartReader.so()(64bit) libhdf5.so.1.8.5()(64bit) libKWCommon.so()(64bit) libMapReduceMPI.so.pv3.8()(64bit) libMoments.so()(64bit) libmpistubs.so.pv3.8()(64bit) libNIfTIReader.so()(64bit) libNIfTIWriter.so()(64bit) libPointSprite_Graphics.so()(64bit) libPointSprite_Plugin.so()(64bit) libPointSprite_Rendering.so()(64bit) libpqApplicationComponents.so()(64bit) libpqComponents.so()(64bit) libpqCore.so()(64bit) libpqWidgets.so()(64bit) libPrismClientPlugin.so()(64bit) libPrismServerPlugin.so()(64bit) libqsqlite.so()(64bit) libqsqlmysql.so()(64bit) libQtCLucene.so.4()(64bit) libQtCore.so.4()(64bit) libQtDBus.so.4()(64bit) libQtGui.so.4()(64bit) libQtHelp.so.4()(64bit) libQtNetwork.so.4()(64bit) libQtSql.so.4()(64bit) libQtTesting.so()(64bit) libQtWebKit.so.4()(64bit) libQtXmlPatterns.so.4()(64bit) libQtXml.so.4()(64bit) libQVTK.so.pv3.8()(64bit) libSierraPlotTools.so()(64bit) libSLACTools.so()(64bit) libSurfaceLIC.so()(64bit) libVPIC.so()(64bit) libvtkalglib.so.pv3.8()(64bit) libvtkCharts.so.pv3.8()(64bit) libvtkClientServer.so()(64bit) libvtkCommonCS.so()(64bit) libvtkCommon.so.pv3.8()(64bit) libvtkDICOMParser.so.pv3.8()(64bit) libvtkexoIIc.so.pv3.8()(64bit) libvtkexpat.so.pv3.8()(64bit) libvtkFilteringCS.so()(64bit) libvtkFiltering.so.pv3.8()(64bit) libvtkfreetype.so.pv3.8()(64bit) libvtkftgl.so.pv3.8()(64bit) libvtkGenericFilteringCS.so()(64bit) libvtkGenericFiltering.so.pv3.8()(64bit) libvtkGeovis.so.pv3.8()(64bit) libvtkGraphicsCS.so()(64bit) libvtkGraphics.so.pv3.8()(64bit) libvtkHybridCS.so()(64bit) libvtkHybrid.so.pv3.8()(64bit) libvtkImagingCS.so()(64bit) libvtkImaging.so.pv3.8()(64bit) libvtkInfovisCS.so()(64bit) libvtkInfovis.so.pv3.8()(64bit) libvtkIOCS.so()(64bit) libvtkIO.so.pv3.8()(64bit) libvtkjpeg.so.pv3.8()(64bit) libvtklibxml2.so.pv3.8()(64bit) libvtkmetaio.so.pv3.8()(64bit) libvtkNetCDF_cxx.so()(64bit) libvtkNetCDF.so.pv3.8()(64bit) libvtkParallelCS.so()(64bit) libvtkParallel.so.pv3.8()(64bit) libvtkpng.so.pv3.8()(64bit) libvtkproj4.so.pv3.8()(64bit) libvtkPVCommandOptions.so()(64bit) libvtkPVFiltersCS.so()(64bit) libvtkPVFilters.so()(64bit) libvtkPVServerCommonCS.so()(64bit) libvtkPVServerCommon.so()(64bit) libvtkPVServerManager.so()(64bit) libvtkQtChart.so.pv3.8()(64bit) libvtkRenderingCS.so()(64bit) libvtkRendering.so.pv3.8()(64bit) libvtksqlite.so.pv3.8()(64bit) libvtksys.so.pv3.8()(64bit) libvtktiff.so.pv3.8()(64bit) libvtkverdict.so.pv3.8()(64bit) libvtkViewsCS.so()(64bit) libvtkViews.so.pv3.8()(64bit) libvtkVolumeRenderingCS.so()(64bit) libvtkVolumeRendering.so.pv3.8()(64bit) libvtkWidgetsCS.so()(64bit) libvtkWidgets.so.pv3.8()(64bit) libvtkXdmfCS.so()(64bit) libvtkXdmf.so()(64bit) libvtkzlib.so.pv3.8()(64bit) libXdmf.so()(64bit)
Requires(rpmlib): rpmlib(PayloadFilesHavePrefix) <= 4.0-1 rpmlib(CompressedFileNames) <= 3.0.4-1
Requires: libCosmo.so()(64bit) libc.so.6()(64bit) libc.so.6(GLIBC_2.10)(64bit) libc.so.6(GLIBC_2.11)(64bit) libc.so.6(GLIBC_2.2.5)(64bit) libc.so.6(GLIBC_2.3.4)(64bit) libc.so.6(GLIBC_2.3)(64bit) libc.so.6(GLIBC_2.4)(64bit) libc.so.6(GLIBC_2.7)(64bit) libc.so.6(GLIBC_2.9)(64bit) libdbus-1.so.3()(64bit) libdl.so.2()(64bit) libdl.so.2(GLIBC_2.2.5)(64bit) libEGL.so.1()(64bit) libfontconfig.so.1()(64bit) libfreetype.so.6()(64bit) libgcc_s.so.1()(64bit) libgcc_s.so.1(GCC_3.0)(64bit) libglib-2.0.so.0()(64bit) libGL.so.1()(64bit) libGLU.so.1()(64bit) libgobject-2.0.so.0()(64bit) libgthread-2.0.so.0()(64bit) libhdf5.so.1.8.5()(64bit) libICE.so.6()(64bit) libKWCommon.so()(64bit) libmpistubs.so.pv3.8()(64bit) libm.so.6()(64bit) libm.so.6(GLIBC_2.2.5)(64bit) libmysqlclient_r.so.16()(64bit) libmysqlclient_r.so.16(libmysqlclient_16)(64bit) libpng14.so.14()(64bit) libpng14.so.14(PNG14_0)(64bit) libPointSprite_Graphics.so()(64bit) libPointSprite_Rendering.so()(64bit) libpqApplicationComponents.so()(64bit) libpqComponents.so()(64bit) libpqCore.so()(64bit) libpqWidgets.so()(64bit) libpthread.so.0()(64bit) libpthread.so.0(GLIBC_2.2.5)(64bit) libpthread.so.0(GLIBC_2.3.2)(64bit) libQtCLucene.so.4()(64bit) libQtCore.so.4()(64bit) libQtGui.so.4()(64bit) libQtHelp.so.4()(64bit) libQtNetwork.so.4()(64bit) libQtSql.so.4()(64bit) libQtTesting.so()(64bit) libQtWebKit.so.4()(64bit) libQtXmlPatterns.so.4()(64bit) libQtXml.so.4()(64bit) libQVTK.so.pv3.8()(64bit) librt.so.1()(64bit) librt.so.1(GLIBC_2.2.5)(64bit) libSM.so.6()(64bit) libsqlite3.so.0()(64bit) libstdc++.so.6()(64bit) libstdc++.so.6(CXXABI_1.3.1)(64bit) libstdc++.so.6(CXXABI_1.3)(64bit) libstdc++.so.6(GLIBCXX_3.4.11)(64bit) libstdc++.so.6(GLIBCXX_3.4.14)(64bit) libstdc++.so.6(GLIBCXX_3.4)(64bit) libstdc++.so.6(GLIBCXX_3.4.9)(64bit) libVPIC.so()(64bit) libvtkalglib.so.pv3.8()(64bit) libvtkCharts.so.pv3.8()(64bit) libvtkClientServer.so()(64bit) libvtkCommonCS.so()(64bit) libvtkCommon.so.pv3.8()(64bit) libvtkDICOMParser.so.pv3.8()(64bit) libvtkexoIIc.so.pv3.8()(64bit) libvtkexpat.so.pv3.8()(64bit) libvtkFilteringCS.so()(64bit) libvtkFiltering.so.pv3.8()(64bit) libvtkfreetype.so.pv3.8()(64bit) libvtkftgl.so.pv3.8()(64bit) libvtkGenericFilteringCS.so()(64bit) libvtkGenericFiltering.so.pv3.8()(64bit) libvtkGraphicsCS.so()(64bit) libvtkGraphics.so.pv3.8()(64bit) libvtkHybridCS.so()(64bit) libvtkHybrid.so.pv3.8()(64bit) libvtkImagingCS.so()(64bit) libvtkImaging.so.pv3.8()(64bit) libvtkInfovisCS.so()(64bit) libvtkInfovis.so.pv3.8()(64bit) libvtkIOCS.so()(64bit) libvtkIO.so.pv3.8()(64bit) libvtkjpeg.so.pv3.8()(64bit) libvtklibxml2.so.pv3.8()(64bit) libvtkmetaio.so.pv3.8()(64bit) libvtkNetCDF_cxx.so()(64bit) libvtkNetCDF.so.pv3.8()(64bit) libvtkParallelCS.so()(64bit) libvtkParallel.so.pv3.8()(64bit) libvtkpng.so.pv3.8()(64bit) libvtkproj4.so.pv3.8()(64bit) libvtkPVCommandOptions.so()(64bit) libvtkPVFiltersCS.so()(64bit) libvtkPVFilters.so()(64bit) libvtkPVServerCommonCS.so()(64bit) libvtkPVServerCommon.so()(64bit) libvtkPVServerManager.so()(64bit) libvtkQtChart.so.pv3.8()(64bit) libvtkRenderingCS.so()(64bit) libvtkRendering.so.pv3.8()(64bit) libvtksqlite.so.pv3.8()(64bit) libvtksys.so.pv3.8()(64bit) libvtktiff.so.pv3.8()(64bit) libvtkverdict.so.pv3.8()(64bit) libvtkViews.so.pv3.8()(64bit) libvtkVolumeRenderingCS.so()(64bit) libvtkVolumeRendering.so.pv3.8()(64bit) libvtkWidgetsCS.so()(64bit) libvtkWidgets.so.pv3.8()(64bit) libvtkXdmfCS.so()(64bit) libvtkXdmf.so()(64bit) libvtkzlib.so.pv3.8()(64bit) libX11.so.6()(64bit) libXcursor.so.1()(64bit) libXdmf.so()(64bit) libXext.so.6()(64bit) libXfixes.so.3()(64bit) libXinerama.so.1()(64bit) libXi.so.6()(64bit) libXrandr.so.2()(64bit) libXrender.so.1()(64bit) libXt.so.6()(64bit) libz.so.1()(64bit)
Checking for unpackaged file(s): /usr/lib/rpm/check-files /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/ParaView-3.8.1-linux64GccDPOpt.x86_64
Wrote: /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.8.1-linux64GccDPOpt.x86_64.rpm
Executing(%clean): /bin/sh -e /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.fU79DL
+ umask 022
+ cd /home/peter/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD
+ cd ParaView-3.8.1
+ rm -rf filelists
Preparing... ##################################################
ParaView ##################################################
Old   December 20, 2010, 18:42
Martin Beaudoin
mbeaudoin will become famous soon enough
This is rather vague....
What is the error message generated by paraview/paraFoam when you load your case?
What is the output of the following command: wmakePrintBuild
Martin
mbeaudoin is offline   Reply With Quote
Old   December 21, 2010, 07:44
This is my output for 'wmakePrintBuild'
1.6-ext-f3a01becc315
I dont get any error when I open paraview or load a case with paraFoam. I can enter ther GUI of paraview with both cases, but I am not able to see the grid. When I close paraview I get than
Inconsistency detected by ld.so: dl-close.c: 731: _dl_close: Assertion `map->l_init_called' failed!
Any Idea?
Old   December 21, 2010, 09:54
Sandeep Menon
deepsterblue will become famous soon enough
I'm pretty sure this is a bug in glibc. Are you using a gcc-4.5.1 / openSuse combo?
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   December 21, 2010, 12:19
Yes. I am using opensuse 11.3 but gcc gcc-4.5.0.
What is that mean?
Old   December 21, 2010, 12:44
Sandeep Menon
Yeah.. It's a general problem with glibc and gcc-4.5.x. The shared libraries aren't unloaded properly by certain class destructors, and so the assertion gets triggered. It doesn't seem to be a major issue, if you're willing to ignore the assertion warning.
I downgraded to gcc-4.4.x, and the problem doesn't exist there. I'll go back up once they fix the issue.
Sandeep Menon
Old   December 21, 2010, 12:48
Thank you very much. How can I downgrade my compiler? Just delete this one and install with yast an older one?
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
kOmegaSST in openfoam 1.6 Gearb0x OpenFOAM 2 March 3, 2010 07:02
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 16:39
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 13:46
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 18:55
