After Update Ubuntu "/opt/openfoam171/bin/paraFoam: 142: paraview: not found"
Old   November 19, 2010, 14:35
Default After Update Ubuntu "/opt/openfoam171/bin/paraFoam: 142: paraview: not found"
Paul
pajofego is on a distinguished road
Hello at all,
yesterday the automatic update of ubuntu wants to update openfoam. The standard solver and tool works fine. But after typing paraFoam I got following message:
Paraview is installed on:
/opt/paraviewopenfoam380/bin/paraview
Typing this command in a console the message is:
"error while loading shared libraries: libpqApplicationComponents.so: cannot open shared object file: No such file or directory"
Is there any workaround to fix this problem.
Best regards
pajofego
pajofego is offline   Reply With Quote
Old   November 19, 2010, 16:02
Paul
o.k. I've to install
sudo apt-get install paraviewopenfoam381
Best regards
pajofego
Old   November 20, 2010, 05:19
Martin
RugbyGandalf is on a distinguished road
hi there, i have the same problem, but it won't work the way pajofego soveld it
i already deinstalled and reinstalled paraview and it won't work
it always says: paraview not found...
in case directory after typing paraFoam it gives out: /opt/openfoam171/bin/paraFoam: line 139: paraview: command not found
has anyone an idea?
thank you
RugbyGandalf
RugbyGandalf is offline   Reply With Quote
Old   November 20, 2010, 06:32
stawrogin is on a distinguished road
I had the same problem, but I fixed it with pajofeg's tip. Thanks for it.
Stawrogin
stawrogin is offline   Reply With Quote
Old   November 20, 2010, 10:00
Michele Vascellari
mighelone is on a distinguished road
After install paraview, you need to update your environmental setting:
# source /opt/openfoam171/etc/bashrc
after that everything works!
mighelone is offline   Reply With Quote
Old   November 20, 2010, 16:52
Martin
Thank you very much, that was working
Old   November 24, 2010, 13:46
Bertrand Delvaux
Bertrand is on a distinguished road
For me it's still not working
Bertrand is offline   Reply With Quote
Old   November 25, 2010, 04:42
Martin
as told before, it worked for me, after typing
into the terminal.
Please check if your OpenFoam - bashrc ist also sitiuated in the path mentioned above. Are the versions the same?
What about typing only paraview in Terminal?
RugbyGandalf
Old   December 8, 2010, 08:01
Kurne
kurne is on a distinguished road
Dear Bertrand
I am also facing the same problem but it is solve by the installing the cmake and its really work for me hope it will also work for you.
Simulation Is Determination Of Imagination Towards Approximation ®
Best Regards
Mubeen K Kurne
kurne is offline   Reply With Quote
[OpenFOAM] Update data in ParaView hpon ParaView 18 May 10, 2015 15:55
Thumbs up Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 8 December 18, 2009 12:14
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 21 September 17, 2009 12:27
[OpenFOAM] Paraview 3.4, ppa.launchpad.net and Ubuntu francois ParaView 1 May 29, 2009 10:07
