[blockMesh] blockMesh with double grading.
Like Tree68Likes
Old   May 24, 2013, 07:17
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Bruno
I need it on OF 2.2.0
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 24, 2013, 07:30
akidess's Avatar
Anton Kidess
Originally Posted by immortality View Post
Hi Bruno
Ehsan, go ahead and try the code and see if it works. There is a good chance no changes are required.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   May 24, 2013, 08:29
Ehsan
OK.thanks.compiled without error.
but in conventional way we have for example:
hex (0 1 4 3 9 10 13 12) (400 40 1) simpleGrading (2 4 1)
in (2 4 1) each number is related to (positive x-direction,y-direction,z-direction)
and its clear.
but in simpleGrading how it is implemented?
I expected something like: ((1 2 3)(4 5 6)(7 8 9)) for double grading,could anyone enlighten me?
hex (0 1 2 3 4 5 6 7) (20 10 20) simpleGrading (-5 1 1)
Old   May 24, 2013, 19:15
Retired Super Moderator
Bruno Santos
Greetings to all!
@Anton:
Originally Posted by akidess View Post
Bruno, did you ever test it on 2.2? If so, we could add the 2.2 template to the wiki...
Nope, I only had time to build it and to fix the zip related instructions. I'll try to give it a spin tomorrow, using the case from post #25.
@Ehsan: Check the wiki: http://openfoamwiki.net/index.php/Co...ckMeshDG#Usage - and check the examples shown in this thread you're reading.
Best regards,
Bruno
Tushar@cfd likes this.
Old   May 25, 2013, 04:47
Steve
greenleader is on a distinguished road
I've used it with OF v2.2.0 - no issues with it - it just works!
wyldckat likes this.
greenleader is offline   Reply With Quote
Old   May 25, 2013, 06:34
Ehsan
its only this:
For example, simpleGrading (1 -2 1) in blockMeshDict means the created mesh has cells two times larger in the center than those at the side.
which side we are talking about in grading?if its a 3D mesh it means it has less cells in the middle of domain but we want both sided grading in each face of domain.
what we can do when we want different grading in different directions?it seems nothing!
although this work is valuable but has some defects in it.
Old   May 25, 2013, 08:15
Bruno Santos
Greetings to all!
@Steve: Many thanks for the report!
@Anton: Wiki page updated.
@Ehsan:
"simpleGrading (1 -2 1)" - The minus 2 is for the Y direction.
You might not see much with just "(1 -2 1)", because it's just an example; it implies that the person reading the instructions already has some experience with blockMesh's original grading capabilities, which are explained in the OpenFOAM User Guide, section "5.3 Mesh generation with the blockMesh utility", more specifically subsection "5.3.1.3 The blocks": http://www.openfoam.org/docs/user/blockMesh.php
Best regards,
Bruno
Old   May 25, 2013, 08:41
Ehsan
thanks.so it only do double grading.if someone likes single grading in x-direction as well as double grading in y-direction can combine blockMesh and blockMeshDG together?I still think we need a more powerful tool in meshing.
I tested it by a very coarse mesh:
hex (0 1 2 3 4 5 6 7) (10 8 1) simpleGrading (-2 -4 1)
and works fine as the attachment.it made me free of so many excess points and blocks!
the_ichthyologist likes this.
Old   May 27, 2013, 07:36
Default Uneven number of cells
  #49
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I noticed a problem when using double grading and an uneven number of cells.
GerhardHolzinger is offline   Reply With Quote
Old   May 27, 2013, 08:41
akidess's Avatar
Anton Kidess
Please attach your blockMeshDict.
Old   May 27, 2013, 08:48
Gerhard Holzinger
Here is my blockMeshDict.
Old   May 27, 2013, 09:04
akidess's Avatar
Anton Kidess
Gerhard, I think your edgeGrading is botched. Double check while referring to figure 5.5 of the user manual for the edge numbering.
Edit: I take that back for now Need to look into this a bit more carefully.
Old   May 27, 2013, 10:54
Steve
Yes, I seem to recall that doublegrading does not work with an odd number of cells. I always make sure I use an even number.
Old   July 23, 2013, 09:49
Default In combination with edge Grading
  #54
Aditya
kingmaker is on a distinguished road
Hello
Do any one know if this utility works with edge grading also.. ?
Like if we say one of the values in edge grading to be -ve ... will that edge be graded on both sides .. ??
Thank you
kingmaker is offline   Reply With Quote
Old   July 23, 2013, 10:06
akidess's Avatar
Anton Kidess
I think Gerhard had success using edge grading. Just be sure to specify an even number of cells.
Old   July 23, 2013, 10:27
Default Snappy Hex Mesh and BlockMeshDG
  #56
Aditya
Hello Thank you for your answer. I will try and post if I have any problems.
Mean while, I have one more question, can we use snappy hex mesh after blockMeshDG with out any problems ... ??
Thank you
immortality likes this.
Old   August 1, 2013, 05:40
Default Some problem with lineDivide.C
  #57
ME
roamer is on a distinguished road
Hello Everyone,
Thanks for sharing. But for some meshes using this "double grading" create high aspect ratio meshes and non-orthogonal faces.
I found that a minor editing to the file curvedEdges/lineDivide.C solves the problem.
        if ( xratio > 0 )
        for (label i=1; i < ndiv; i++)
            divisions_[i] = (1.0 - pow(xratio, i))/(1.0 - pow(xratio, ndiv));
        else
                if ( i <= ndiv/2.0 )
                    divisions_[i] = (1.0 - pow(-xratio, i))/(1.0 - pow(-xratio, ndiv/2))/2;
                else
                    divisions_[i] = 1.0-(1.0 - pow(-xratio, ndiv-i))/(1.0 - pow(-xratio, ndiv/2))/2;
To this:
        if ( xratio > 0 )
        else
                    divisions_[i] = (1.0 - pow(-xratio, i))/(1.0 - pow(-xratio,ndiv/2.0))/2.0;
                else
                    divisions_[i] = 1.0-(1.0 - pow(-xratio, ndiv-i))/(1.0 - pow(-xratio, ndiv/2.0))/2.0;
I hope it helps somebody.
wyldckat and pjohannes183 like this.
roamer is offline   Reply With Quote
Old   August 1, 2013, 05:51
akidess's Avatar
Anton Kidess
I pushed your patch to the repository: http://code.google.com/p/blockmeshdg...a63253d80a5c93
If you would like to be acknowledged differently please let me know.
Old   August 1, 2013, 10:55
Ehsan
Hi Anton
I can't have access to this link by this message "Request not allowed from your country That’s all we know."could you upload it anywhere else?
thanks.
Old   August 1, 2013, 11:15
akidess's Avatar
Anton Kidess
Sorry Ehsan, but I do not have the time to repackage and re-upload every commit. The code changes however are minimal and are within this thread, so you could easily make your own executable.
fvOptions npatricia OpenFOAM 6 May 23, 2018 06:21
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Warning message C4133 while compiling Arminius Fluent UDF and Scheme Programming 0 October 2, 2017 12:44
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
