November 9, 2009, 06:16 |
#141 | |
Bernard Esterhuyse
Rep Power: 17 |
Hi
I'm a relatively new OpenFOAM user, but I already feel the potential of a truly open source CFD code is immense. I have read through all the posts in this thread, and I must commend Alberto for the effort he has invested in this. I would like to answer the questions posed by Alberto (I think all community members should provide their answers so we can get a clear idea of what route to follow): Quote:
2. A formal documentation project like the FOAM documentation project I have seen a similar type of scenario in the Content Management System world with the Joomla fork of Mambo. The central issue was also one of copyright ownership. The Joomla fork has been very successful, in fact more so than the original Mambo system. You can check this article for more info (its a little old though): http://www.thejemreport.com/content/view/212/1/ |
November 9, 2009, 08:13 |
#142 |
Mark Olesen
Rep Power: 40 |
Posting Removed
November 9, 2009, 08:55 |
#143 | |
Bernard Esterhuyse
Rep Power: 17 |
Hi Mark
I wouldn't suggest that the two scenarios are identical. I certainly don't try to suggest anybody is attacking OpenFOAM. The following section of the article just illustrates that there were similar issues: Quote:
November 9, 2009, 09:32 |
#144 |
Mark Olesen
Rep Power: 40 |
Posting removed
November 9, 2009, 10:08 |
#145 |
Bernard Esterhuyse
Rep Power: 17 |
I agree, you should not be able to use names that are mis-representative or misleading. However, would the same apply if I wanted to present a conference or a workshop on OpenFOAM? Would it mean I cannot mention OpenFOAM in the name of the conference or in any documentation?
November 9, 2009, 10:23 |
#146 |
Mark Olesen
Rep Power: 40 |
Posting Removed
November 9, 2009, 12:16 |
#147 | |
Alberto Passalacqua
Rep Power: 36 |
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
November 9, 2009, 13:01 |
#148 | |
Alberto Passalacqua
Rep Power: 36 |
nobody is attacking OpenFOAM(r) and OpenCFD(r). If you carefully read this discussion from the beginning, many opportunities to talk (talk, not agree) were offered, and various alternatives were considered. This thread simply reports what happened, and discusses about it, openly. The whole point of the discussion is to find a solution that allows a formal documentation project to be created and effectively maintained by the community, without worrying about potential legal litigations. The fact this solution might be identified in a formal fork from the upstream release is due to external factors not under the control of the community and of its contributors. As a consequence this can be hardly interpreted as an attack, but should be seen, if it will happen, as a painful consequence of the failure of other attempts. Best,
November 9, 2009, 17:07 |
#149 |
Mark Olesen
Rep Power: 40 |
Posting Removed
November 9, 2009, 21:01 |
#150 | |
Alberto Passalacqua
Rep Power: 36 |
in my previous message I simply stated that nobody attacks OpenFOAM(r) and OpenCFD(r), as it should be clear from this thread. I'm sorry if it could be interpreted otherwise, but my intent was simply to state that once more. I find that making this point very clear is extremely important for different reasons:
Best,
November 10, 2009, 03:21 |
#151 |
Mark Olesen
Rep Power: 40 |
Posting removed
November 10, 2009, 03:38 |
#152 |
Bernard Esterhuyse
Rep Power: 17 |
Hi Alberto
I have three questions regarding a possible fork (as mentioned earlier): 1. You mention that there will be a lot of work involved. What do you see as the areas where the most work will be required? 2. If OpenCFD regards a fork as a hostile move, what do you think will be their reaction to it? 3. What do you think will be the community's reaction to a fork - will it be regarded as positive, or will it create confusion? Regards Bernard |
November 10, 2009, 09:00 |
#153 | |
Alberto Passalacqua
Rep Power: 36 |
Thanks, Alberto
November 10, 2009, 09:26 |
#154 | |||
Alberto Passalacqua
Rep Power: 36 |
About their specific reaction, I frankly cannot know what it will be. Quote:
It is our task to clarify the doubts and remove the confusion, and this can be achieved in my view with a clear message when the fork is announced, and providing transparent information to the community. In particular, a clear plan should be prepared to inform them about
Best,
November 10, 2009, 17:11 |
#155 | |
Paul Schiefer
Rep Power: 17 |
If it is too much work to find a new name, I can offer to start my random string generator. There is already enough confusion with OpenFOAM, OpenFOAM-dev and OpenFOAM-extend. Adding another name won't hurt. If there was real need for Alberto's documentation project, somebody would have taken the necessary steps. So let us thank him for his initiative, and let the project rest until somebody takes the responsibility instead of discussing that it is too much work. |
November 10, 2009, 20:01 |
#156 | |
Alberto Passalacqua
Rep Power: 36 |
I think it would be less responsible to fork in a hurry just to do that, create further confusion in the community, and then let the project die because of lack of resources to keep it in good shape. This said, I agree with you. The discussion is stuck since I did not see crowds of volunteers offering their help, supporting a fork or an alternative initiative. Without volunteers it is not possible to proceed, at least if you want to create a sustainable project. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; November 10, 2009 at 20:24. Reason: Typo |
November 11, 2009, 03:17 |
#157 |
Florian
Rep Power: 17 |
Most people who can support the new project with contributions are probably already active with the -dev/-extend/freefoam projects. I think it is most important to convice them to put their effort in a new single project and merge the extensions.
As a user I will be very happy to support a fork just by using it and maybe becoming a contributer at a later time. Another important point, the documentation project has already been started but paused and could be reactivated. IMHO the doc project should be affiliated closely with a fork (developers are the people who know the code good enough to write documentation though they don't like it usually) I wouldn't infer from a lack of discussion here that there won't be any contributers. They are there are already, it will be the challenge to unite them. From my point of view the next steps would be: - Convince the (three AFAIK) extension projects from the general idea of a fork - Find a new name - Set up a common repository at sourceforge or something like that - Merge the code Though at this point there hasn't been created any new code it gives a user a single checkout which also includes the dev and extend and hopefully also uses the freefoam build system. Now see how the project evolves. If it keeps a close track with the openFoam distribution there is no problem in porting features (in both directions). |
November 11, 2009, 11:18 |
#158 | |||||
Alberto Passalacqua
Rep Power: 36 |
Best, Alberto
November 15, 2009, 02:18 |
GFDL anyone?
#159 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hello to all,
I'm sorry to intrude, but I've tried to read the most of this thread, and also used the forum's search engine and I couldn't find a single reference to the GNU Free Documentation License (GFDL) on it. Right on the GFDL preamble states: Quote:
So, my questions are:
(edit: post clutter moved to here) I just hope for the best and am willing to help as I can. Best regards, Bruno Santos ----- Disclaimer: This post does is in no way reflect the position of the company I work for, on this matter; nor am I related to OpenCFD(R) nor to the developers of OpenFOAM(R). I have no legal/copy rights over OpenFOAM(R)... and probably should've kept my mouth shut, since I'm just a newbie in this community.... Last edited by wyldckat; November 16, 2009 at 19:36. Reason: Moving ranting out of the thread... |
November 15, 2009, 11:15 |
#160 |
Paul Schiefer
Rep Power: 17 |
>Both the user and programmers guides that OpenCFD has made for OpenFOAM are
>under the GFDL. This (I think) implies that any documentation done without the >permission from OpenCFD, and in reference to OpenFOAM, should be done with the >same license. What you think is wrong. Only because some documentation on OpenFOAM is published under GFDL does by no means imply that every new documentation must be GFDL. >Especially because OpenFOAM's code is under GPL. The code license has nothing whatsoever to do with the documentation license. >I believe these questions are valid for the previous project, as well as a future fork >project, because I believe that in it's (future) heart, it will still use OpenFOAM >technology, whether it has a new name or not! To use or not to use, this is the question. http://www.opencfd.co.uk/openfoam/ distributes the software under the GPL. This gives every user all rights from the GPL, and not all rights from the GPL minus the restrictions from some trademark policies. I can call a multiplication function "Paul technology" and publish it under GPL. But I cannot force everybody who uses multiplications to acknowledge the use of Paul technology. >I just hope for the best and am willing to help as I can. One thing that will certainly help is not to add more confusion to this discussion. |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam/69068-foam-documentation-project-shut-down.html
Posted By | For | Type | Date | |
?????????So-net blog | This thread | Refback | October 18, 2009 19:46 | |
Horse Bits | This thread | Refback | October 17, 2009 16:36 | |
OpenFOAM(r) related posts removed | This thread | Pingback | October 13, 2009 13:57 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
